C1246 Master Cylinder Pressure Sensor
Discussion in 'Gen 3 Prius Main Forum' started by Dilan Gero, Oct 25, 2016.
  1. ChapmanF
    18,891
    (y)
  2. autoz
    autoz Junior Member
    22
    16
    Trindad
    2013 Aqua
    Thanks Chap, I was also able to do the adjustment as per Toyota instruction manual with setting the stroke sensor, good car is now working again.
    Thanks again.
  3. Virantha Perera
    Virantha Perera New Member
    Sri Lanka
    Hi Chap Sir,
    i have Toyota harrier 2008 hybrid which is domestic Japan model of Lexus RX400h. I had an issue with my master brake cylinder last year and I changed it with the used part and I spent around $1200 issue was 1) C1246 - master Cylinder pressure sensor
    2) C1256 - Accumulator low pressure
    now again I am getting the same issue and my Acumirator motor runs continuously with 10sec bracks. since I saw this post and above someone says your suggestion worked and I just wondering can mine also sorted. can you please help me?
    regards
    Virantha
