C1256
Discussion in 'Gen 2 Prius Technical Discussion' started by jbv7, Jan 21, 2019.
  1. jbv7
    jbv7 New Member
    se wisconsin
    My daughter has a 06 Prius. I am not sure of the pkg. She is in college in IL and called me yesterday and said she got a brake light, check engine and the triangle with the exclamation point. I had her take to an o'riley auto parts to get it scanned. Attached are the pics. She said the brakes do not feel any different nor does the car drive any different. Could this be battery related? I sent the scan to a toyota dealer and they said $2700 with out even seeing the car. IMG_9718 2.JPG IMG_7075.JPG IMG_5139.JPG
  2. ChapmanF
    19,054
    Probably not battery related, as the condition is likely detected when the car is in READY and there is plenty of power coming from the converter, not the battery. Your second attachment shows what the detection conditions are.
    If the brakes don't feel any different yet and the car doesn't drive any differently yet, then this trouble code has done what it is there to do: warn you of trouble before it's too late.
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    I had identical codes on one of my Venzas. It was an ABS sensor. I don’t remember the cost but it was hundreds not thousands of dollars.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    ABS actuator failure is becoming quite common. How many miles on the car?
    Check the engine oil too asap.
    Skibob likes this.
  5. jbv7
    jbv7 New Member
    se wisconsin
    165000, moved my post, sorry for the delay
  6. chronon
    chronon Active Member
    601
    106
    here and there aint be in frozen wasteland no mo..
    amazing that about 165000 is when this happened on my 05 as well ... is this a coincidence ?
  7. ChapmanF
    19,054
  8. chronon
    601
    106
    is that some kind of statistical bell curve .. showing the top 68% of failures occurr within 1 sigma of an average useage amount ?
  9. ChapmanF
    19,054
    Couldn't have said it better myself.
    chronon likes this.
