C1259 and red triangle after hybrid battery rebuilt and ECM sent out for repair
Discussion in 'Generation 1 Prius Discussion' started by VacantStance, Dec 22, 2019.
  1. VacantStance
    VacantStance Junior Member
    47
    Mid Atlantic
    2002 Prius
    I recently pulled and tested my HV battery pack out of my 2002 Prius and found a single cell that needed to be replaced. After returning the battery pack to the car, I began to get random misfire codes(P3000) so I had a friend check it out. He thought that maybe the ECU was the culprit, so I sought out a solution on Ebay. There is a Seller offering to repair your ECU for $80. You ship it to him, he diagnoses the ECU and repairs it and returns it in a timely fashion. I won't name the Seller because I personally had a bad experience. He contacted me maybe two weeks after receiving my ECU and told me over the phone that he could not determine if my ECU was bad or not, but he could sell me a reconditioned one, already programmed for $400. It felt like a bait & switch so I refused the offer over the phone. He agreed to return my ECU to me and refund the $80...and he did return my ECU, but kept the $80. I was not aware, but apparently he was that if a transaction falls outside of the allotted time Ebay won't investigate fraudulent returns. He basically held on to my ECU until Ebay refused to look into it. My credit card company is investigating the bogus return.
    So far, I'm out of the $80 but my ECU finally arrived back to me. I re-installed it into my car and now all I get is the following code:
    C1259 TOYOTA - HV System Regenerative Malfunction
    The red triangle frequently appears so I'm hoping that replacing the ECU will do the trick. Any recommendations on a trustworthy place to purchase one? What exactly is involved with making it compatible with my vehicle? I'm open to a salvage yard unit, but not if it will just cause me more problems.
  2. ChapmanF
    15,111
    C1259 is just a code that your Brake ECU will show to say "hey, I heard that the HV ECU has a code it wants you to know about." So the important code you need to look at is whatever the HV ECU is reporting.
    What are you using to read codes? Sometimes people use a generic scan tool that will know about getting codes from a brake ECU (lots of cars have brakes, right?) but not from an HV ECU (what's that?), and so such a scan tool will show you the C1259 code from the brake ECU, but none of the HV ECU codes it's trying to point you at.
    If you read codes with Techstream and it shows the HV ECU is clear of codes, then the C1259 is just remembered in the brake ECU from some past time when the HV ECU had some codes, and can be cleared.
  3. VacantStance
    47
    Mid Atlantic
    2002 Prius
    I'm reading the codes from an Actron CP9580A Enhanced AutoScanner Plus scan tool. I'll read them from my Techstream software once my laptop becomes available, but until then, I'll research whether my Actron can do the job properly.
    So if I'm clearing the codes with my Actron and red triangle is disappearing it's really not clearing? It comes back soon after I clear it. I assumed the issue was triggering it.
  4. ChapmanF
    15,111
    Right, if warnings come back after clearing, they're telling you about something real, so you'll want the codes.
  5. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    In addition to what Chap has said, P3000 is not the random misfire code (P0300), so is that a typo, or a misinterpretation on your part?
    If it is truly a P3000 then that goes with the C1259, but again is just a code that your HV control ECU will show to say "hey, I heard that the HV battery ECU has a code it wants you to know about." The code reported by the HV battery ECU is what you're after.
  6. VacantStance
    47
    Mid Atlantic
    2002 Prius
    Sorry, just a typo. The code is P0300.
  7. VacantStance
    47
    Mid Atlantic
    2002 Prius
    I finally got my laptop updated and I was able to run the Techstream diagnostic software. I found a P3000 & a P3009. They both had “History” status. I cleared them and so far the car has been running like a dream. I’ve only put about 20 miles on her so I’ll continue to drive her until the OBDII status shows that I can get it inspected. I hope this solves the issue. I miss putting 80 miles a day commuting back and forth to work for like $12 a week. I’ll be back should anything else arise. Thanks a bunch!
    dig4dirt likes this.
  8. ChapmanF
    15,111
    If the P3009 ever comes back, I would recommend chasing it down. It may come and go with humidity, etc. Having only one voltage leakage path is not a big deal by itself; the car detects it and gives you the code so it can be fixed. It's possible, though, to ignore one such path long enough that a second one can form, and complete a circuit.
