C1310 and C1259
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mehmet alb, Jun 29, 2022.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    I changed the brake pads and discs. but I did not unplug the 12 volt battery while changing it. Could the problem be caused by this?
    red triangle, vsc and yellow exclamation point all started to light up.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Mehmet alb likes this.
    52,863
    what are the symptoms?
  4. ChapmanF
    19,035
    Those two exact brake codes are such special ones that it would be good for everyone to know them from memory.
    Those are the two brake codes that tell you there are hybrid-system codes you need to read. That's all they mean.
    So, whenever you see those two brake codes, go read the hybrid-system codes with your scan tool, and pay attention to those.
    If you are using a scan tool that can't show you the hybrid-system codes, so you see only these two brake codes and not the actual important ones they are telling you about, then the thing to do is obtain or borrow a scan tool that can, or visit a shop that has one, and find out what the hybrid-system codes are.
  5. Mehmet alb
    77
    Turkey
    I didn't pull out the orange HV security plug, I didn't put the battery in. and the po 420 gives the catalatic error. the o2 sensore is a misleading tactic, and the po420 error is no longer responding. The car is having difficulty moving from 110 to 120. will it be okay if I empty the catalytic filter? is there any harm to the arba when the catalytic filter is inserted?
  6. Mehmet alb
    77
    Turkey
    Turuncu HV güvenlik fişini çekmedim, pili takmadım. ve po 420 katalat hatası veriyor. o2 sensörü yanıltıcı bir taktiktir ve po420 hatası artık yanıt vermiyor. Araç 110'dan 120'ye geçmekte zorlanıyor. katalitik filtreyi boşaltsam sorun olur mu? katalitik filtre takıldığında arbaya bir zararı olur mu?
  7. Mehmet alb
    77
    Turkey
    Fren balatalarını ve diskleri değiştirirken turuncu HV emniyet fişini çekmedim, pili takmadım. pil kafasını çıkardım ve değiştirdim, tüm ariza gitti, şu anda bir sorun yok gibi görünüyor. Geri verir mi bilmiyorum. ve po 420 katalatik hata verir. o2 sensörü yanıltıcı bir taktiktir ve po420 hatası artık yanıt vermiyor. Araba 110'dan 120'ye yokuşta zorlanıyor. Katalitik filtreyi boşaltsam olur mu? katalitik filtre iptal edildiğinde arba'ya bir zararı olur mu?
  8. ChapmanF
    19,035
    There must be trouble codes other than P0420. P0420 is an engine trouble code, but you also have hybrid-system trouble codes. We know that, because you have C1259 and C1310, which tell you that there are hybrid-system trouble codes.
    Once you have access to a scan tool that correctly retrieves the hybrid-system codes, posting those here will allow us to offer more help.
