c1343 Hydraulic System(RR) help requested
Discussion in 'Gen 2 Prius Technical Discussion' started by Douglas88, Jun 26, 2022.
  1. Douglas88
    Douglas88 Junior Member
    43
    missouri
    My 2005 Prius is getting c1343 hydraulic system RR trouble code. All the usual brake error lights, vsr, abs, brake, come on. I have done the full bleed procedure using tech stream. I do not know how to read any further the sub codes unless the RR is a sub code, is it?, but am posting the freeze frame image below, titled "June 26 22 c1343 hydraulic system RR error F frame." I cant figure out what I need do to fix this. IT goes for usually a few days or more before returning the code again after a reset. ON the freeze frame I can not see the issue. PERHAPS someone with greater knowledge can take a look and point me forward to what is going on.
    I did notice that ...while the code was active, and not reset, if I put my foot on brake and hold it there and read the active data, it would show 0.66 value for SLRRL Solenoid Current, and 0.00 for all the other wheels, including for SLRRR. This seems strange to me, but do not know what it means. I am including this active data image below under the title of "steady on brake june 26 22 active data" . However after reset of the code, if I do this again, hold foot on brake and read active data, I get symmetrical readings between SLRRL, and SLRRR, with SLRRL Solenoid Current =0.63 and SLRRR=0.64. I am posting the image for this active data below under title of "June 26 steady brake on active data AFTER clearing codes, now rr and rl same pressure". I am also including an image of the active data, codes not cleared, with my foot off the brake in case that is helpful, under the title "steady on brake June 26 22 active data". Anyone have any thoughts please? Thank you much.
    #1 Douglas88, Jun 26, 2022
  2. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    It is right there at the top of your FFD: Detailed Freeze DTC 571. You can look up all the details in the repair manual.
    It means Hydraulic pressure control on the RR (right rear) wheel has deteriorated. Likely trouble areas are:
    • Fluid leakage
    • Brake actuator
    Follow the inspection procedure in the repair manual to pin it down.
    Complete Diagnostic for DTC C1343 | Rear Hydraulic System RR Malfunction
  3. Douglas88
    43
    missouri
    Thank you Greatly! I will go after it and update the thread as I progress. I never knew how to find the Detailed Freeze DTC. Sure enough there it is... great!
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    As noted in the diagnostic steps, you've checked for external brake fluid leaks and for correct adjustment of both rear brakes?
    The brake ecu monitors the pressure for each wheel with pressure sensors in the actuator assembly. I assume that if one corner (RR) takes longer to reach a target pressure, or can't achieve that target (compared to LR), then it will set the code.
    You might try logging data with Techstream during a few road tests. See if changes in pressures or solenoid current are any different left to right. (Scantool might not be fast enough to catch what is going on, but it can't hurt to try).
  5. Douglas88
    43
    missouri
    Thank you so MUCH! Now I know how to "see" the deeper codes. I followed the instructions for bleeding. (though it was challenging because the manual only shows what would be displayed and named for the required functions, on an old style test instrument, and the names of the functions needed to go though the bleed procedures FULLY, seem to be quite different, between the manual and the tech-stream names for available functions to select for under active functions, so I had to guess and stumble my way along, best I could .... wonder if there is a "translation" for these differences posted anywhere? After completing this, lengthy full process I remembered that the emergency brake was too lose to grip and stop well...decided to adjust for this...and then....found the shoe adjusters in back fully turned in...leaving way too much travel for e brake, and PROBABLY/Possibly? was the real cause of the error code all along, since too much fluid was needed to get the shoes to the drum...causing the error...just suggesting for others to check this first...with this error code. Also I find there is nothing keeping the adjuster from turning back in over time, no tab hitting on it for one way turning. Should there be one? I do not have one on either side of the rear brakes...wondering about this. (if someone left it off, or if this is how they are on 2nd gen Prius? Effectively the adjuster can't auto self adjust it seems to me, which would be different from what I am used to. Again my thanks for the above Super great help, that let me know how to proceed with this repair effort! I think i probably have succeeded, time will tell for sure.
    James Analytic likes this.
  6. dolj
    dolj Senior Member
    8,645
    4,395
    Yes, there should be an auto-adjust mechanism. From what you say, it sounds like someone might have assembled the brakes incorrectly. The repair manual should have disassemble/inspection/assemble instructions. Maybe compare what the manual says should be there to what you see.
  7. ChapmanF
    19,020
    There should be a small stamped kind of L shaped lever attached to each leading shoe with a spring, with the bar of the L resting on the teeth of the starwheel.
    A subtle thing to be sure to look at is that the starwheel adjusters for the left and right sides are mirror images. The threads are different. If they are mixed up left for right, then the adjust action will actually loosen them, until they are fully turned in as you found them.
  8. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Here's a couple pics from the book: Screenshot_20220705-230504.jpeg Screenshot_20220705-230324.jpeg Screenshot_20220705-230111.jpeg
    Looking at things, it seems that the starwheel with the right hand thread goes on the left side and vice versa.
    James Analytic and dolj like this.
  9. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    Check out the following video:
    Code:
    https://youtu.be/GcAcUBGTVQ8?t=1351
    Start at: 22:31
    How To Replace Rear Brake Shoes 1995-2010 Toyota Corolla
    Jimthecarguy
    Good Luck!
  10. ChapmanF
    19,020
    I'm not sure I've thought it out in that level of detail, but do make sure that whichever adjuster you're going to put on, on whichever side of the car, gets longer, not shorter, when you flick downward on the teeth where the adjust lever touches it. :)
    Tombukt2 likes this.
  11. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,517
    Durham NC
    But I would think that would be a real stretch to even think the adjusters all the way in or even mostly all the way out aren't going to affect hydraulic fluid travel once the system sees it the one time The fluid stays down there when you release the brakes the fluid doesn't all come back it just doesn't have pressure on it to keep things squeezed I would think. But I had the same code just mine was LR I changed the actuator silver and black thingy behind the inverter and all this went away I didn't even use tec stream to bleed. It was almost as easy as bleeding any regular car supposedly I may have air still in the system but the brake pedal feels better than a new one and seems to be working great.
  12. ChapmanF
    19,020
    Sounds like you're thinking of disk brake calipers, which really do work that way. Aside from the 0.3 mm or so that the rubber piston seal springs back, nothing actively pushes the piston back in, and the fluid just stays down there without pressure.
    The drum brakes are different. The brake shoes have big return springs that really do pull them back and force the brake fluid back. The adjusters are all that stops them. If the adjusters are all the way in, the shoes will have a large journey outward, and an equally large journey back.
  13. mr_guy_mann
    4,114
    2,012
    NJ-USA
    And if the drum brake wheel cylinders have to travel too far before the shoes make contact, then it can take too much time before the fluid pressure in that hydraulic circuit increases.
    That makes the brake ecu sad, and then it sets codes and stops trying to apply that corner because it thinks there might be a fluid leak.
    Also, the rear hydraulic brakes on the Gen2 are 100% controlled by the ecu. There is NO connection between the pedal and the rear brakes- at all. Air in the rear circuits or loose shoe fit- pedal will feel fine.
    Heck, until the system goes to "fail safe" mode, nothing in the front brakes will affect pedal feel either.
    #13 mr_guy_mann, Jul 15, 2022
  14. ChapmanF
    19,020
    You can sometimes notice a bigger-than-usual whooshing fluid sound as the friction brakes are applied.
    It's extra noticeable if you are braking gently to a stop, using mostly regen, and then as your speed drops below 7 mph or so, you hear a sudden whoosh.
    But once the ECU has become sad and stopped trying to apply that corner, no more whoosh.
  15. James Analytic
    411
    63
    Michigan
    I second that and thanks for asking as well! Now, how did time tell? Do tell!
    I'm amazed the similarity with my RR value from the same code and was reported when I invested in that all the brakes were recently changed other than the ABS Actuator-Accumulator assembly. The sellers repairman thought everything was OK and safe, though to plan on the ABS Actuator assembly needing replaced eventually and there will be more warning lights and creep mode worse situation.
    My FR Wheel Cylinder is 0.94, FL 0.92, RR 0.66 and RL 0.88. Same RR and code. I have 2.2 for FR & FL Target Oil Pressure and 2.0 for RL & RR.
    I'm still trying to round up all the other parts and get before I start jacking her up and working on.
