c1345 code , Brake Actuator replace?
Discussion in 'Gen 2 Prius Technical Discussion' started by idagon, Apr 22, 2013.
  1. idagon
    idagon New Member
    2001 Prius
    I just purchased a 2007 Prius that is throwing this c1345 and also the c1368 code.
    I am using the techstream and have bled the system.
    I have attempted to initialize the linear solenoid valve and recalibrate after resetting the memory. The solenoid will not initialize or recalibrate.
    Am I looking at replacing the Brake actuator assembly?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    We do hear of the Brake ECU failing from time to time here. Since a used one is cheap, and it is a plug in unit, that would also be something to look at.
