c1364/243- with code, spongey brakes. clear code, brakes just fine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Phaul80, Apr 12, 2024.
Tags:
  1. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    I've taken those rubber trim pieces off of other vehicles and just saved them so mine are intact but stuff just gets in there some kind of way
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    I would look at ABS scandata. Specifically what do you see for LF vs RF brake pressure sensor voltage readings? Under most circumstances I would expect the two front brakes to be the same.
    If you suspect that moisture is a contributing factor, then find every connector between the actuator and the ecu. Take all of them apart and look for corrosion (green).
