C1377 capacitor error
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Adam DiPietro, Sep 26, 2021.
  1. Adam DiPietro
    Adam DiPietro New Member
    Juneau
    I have a 2007 Prius with the C1377 capacitor error. I’ve switched the fuses for the ABS 1,2,3 and switched out the power brake control module - twice. I have no idea where to look past these things.
  2. Adam DiPietro
    Juneau
    This is a photo of the tech steam code.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    Open the tab for the ABS system in techstream and look at the codes. Next to the code should be a snowflake icon (freeze frame data)- click on that and it should have the INF or subcodes.
  5. Adam DiPietro
    Juneau
    Thanks for that link. I haven’t had a chance to dove into it for a few weeks - but will take another look. I’ll post again if I find the problem. Many thanks SFO.
    #5 Adam DiPietro, Oct 26, 2021
    SFO likes this.
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Not sure how many miles are on the vehicle, or how strong the HV battery is, but best not to let it sit unused for any real length of time.
  7. ChapmanF
    19,041
    The brake capacitor module is in the back of the car next to the 12 volt battery, if you haven't checked things out back there yet.
  8. Adam DiPietro
    Juneau
    Well I took a hiatus to repair a house - but I’m back at it again. This is the freeze frame data. Looks like value 109. Apologies for the photos of a laptop screen… I know they are a PITA to read. Where should I begin fixing that issue?
  9. Adam DiPietro
    Juneau
    SFO, your guide was spot on. Replaced ABS MAIN 3 fuse. :whistle: Clearly a genius over here. Not sure how that slipped past me. But the problem is FIXED.
    SFO likes this.
  10. CLoyTX
    CLoyTX New Member
    I'm having the exact same error codes. Where's the ABS 3 located?
