C1391 ABS Code - How screwed am I?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RSM151, Oct 28, 2025.
  1. RSM151
    RSM151 Junior Member
    SE
    Unfortunately, yesterday the brakes on my 2014 Prius abruptly changed at the same time the ABS, Traction Control, and Parking Brake lights came on.
    Now that I am home, I hear the sound of a pump engaging for about 1 second every 4-5 seconds. Using techstream, I am able to see the C1391 trouble code.
    Given that the extended warranty period has ended (>10 years), I am somewhat terrified of what this bill is going to be.
    I am relatively handy and am willing to attempt a DIY (or at least some further diagnostic tests to localize the problem). Does anyone have suggestions regarding this? Given the frequency of the pump activating, I am going to try to listen for a leak as I have seen that mentioned previously. Any advice would be greatly appreciated; I'm a medical student and really, really do not have $3500 to spare if there is something I could do myself.
  2. Brian1954
    Brian1954 Senior Member
    2,692
    1,076
    South Central PA, USA
    You will need to use a mechanics stethoscope to listen for an internal leak in the brake actuator. You will probably not hear anything with just your ears.
    A DIY brake actuator replacement is not a very easy thing to do. The best thing is to try to find someone who has already done the job .
  3. BiomedO1
    BiomedO1 Senior Member
    4,633
    2,433
    Left Coast
    OK, so if you hear it leaking - then what?????
    A better path is to check your brake fluid level and make sure the issue isn't a burst brake line or caliper leak.
    If it is the booster/actuator assembly - you can replace it with a used one; but your gambling since that could be at it's end of life too.
    Good Luck......
