C2300 error code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Doraimon108, Feb 5, 2021.
Tags:
  1. Doraimon108
    Doraimon108 Junior Member
    Orland, Ca
    Hello Prius Chat,
    This is my first post on this forum, very grateful for this resource, and hope I can contribute with this knowledge base at some point. I had a power failure a week ago driving down an interstate. The vehicle lost power and was able to pull off to the shoulder. After 15-20 minutes, the vehicle reset itself without codes on the dashboard and was able to drive again. I was able to drive home another 100 miles without incident. After plugging in my OBDII sensor, I got two error codes: P261B and C2300. I was able to replace the engine water pump and reset the code without incident. However, I'm having trouble figuring out how to test for the C2300 error code, Actuator System malfunction. I replaced the 12V battery with a new unit about 2 years ago. Is replacing the actuator something that can be performed at a home garage or left for prius specialists?
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    I’d suggest starting with the Repair Manual (more info) troubleshooting procedure for diagnostic trouble code C2300, Actuator System Malfunction, rather than jumping ahead to replacing the shift control actuator assembly, which is only one of several possible trouble areas mentioned in the procedure.
    If you were able to replace a water pump, I imagine you could follow the step-by-step diagnostic procedure. Ideally, you’d have a Toyota Techstream diagnostic system, but even with your existing code reader, you could still do the wire harness and mechanical checks.
    These steps require only basic hand tools, an inexpensive multimeter, and the ability to get access to the underside of the car. Be careful when probing connectors: even if a connector is disconnected, it’s best to probe from the wire side with very thin test pins, rather than jamming full-size meter probes into the terminals, which can permanently deform them, so they won’t make good contact.
    Trafficat likes this.
  3. ChapmanF
    19,019
    ... and while we're talking about back-probing with thin test pins ... if it is one of the weather-exposed connectors under the hood or outside of the cabin, the wires will have elastomer seals around them where they enter into the connector housing. You face a choice whether to try to sneak the backprobe in through the center hole of the seal, along with the wire, or between the housing and the outside of the seal.
    It might not be obvious from looking, but those seals are typically, I think, fixed under the insulation crimp of the terminal at the end of the wire ... which means trying to probe through the center hole of the seal, where the wire goes through, won't work unless your test pin punctures the seal.
    If you can manage to work the pin past the outer circumference of the seal instead, you might be able to make contact without puncturing the seal. But it might be tricky getting past a ledge in the plastic housing just beyond the seal.
    Elektroingenieur likes this.
  4. Doraimon108
    Orland, Ca
    Thanks for your reply and advice. I just got a Mini-VCI and trying to complete the techstream installation. I get stuck on the page that requires dealer codes and registration. Is there a link to how to install this properly? I've got an old lenovo laptop with Windows 10Pro I'm repurposing to be a diagnostic tool. Thanks. Also, after the water pump install, I'm now hearing a loud high frequency sound coming from the engine block somewhere it didn't used to have. The pump is brand new from the toyota dealer.
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    That’s true.
    I’ve adapted one of Toyota’s connector cross-section drawings to show the two techniques:
    That’s not an ordinary multimeter probe, of course, but rather a thin test pin, as sold in the Kaise 795, Fluke TP40, or Electronic Specialties 142-5 sets.
    davecook89t likes this.
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    I think you can enter anything you wish in the Dealer Code field.
    As for registration, if your copy of the Toyota Techstream software was obtained as part of a Professional Diagnostic subscription to techinfo.toyota.com, see the Installation Instructions (PDF), pages 9–12. Enter the Software ID shown on your computer into the Techstream Software Registration page, accessible to subscribers, which replies with a key to enter into your computer.
    I have no advice to offer about Techstream software (for U.S.-specification vehicles) from other sources.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    If you got your vci and techstream from a "3rd party seller" (ebay or amazon) contact them and ask about how to make it functional.
