C2311 error
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by M.Aqrbawi, Sep 1, 2016.
  1. M.Aqrbawi
    M.Aqrbawi Junior Member
    Jordan
    hello,
    i have 2013 Prius, it have a problem when there is an electrical load in the car (AC on, Lights on) or some times without AC or lights only by pressing brakes a message on the dash appears (P lock malfunction when parking park in flat place and apply parking brake securely), i scanned it using techstream a C2311 code exists, i checked the 12V battery its good and showing 12.4V while its OFF, and 14V while the car is ON, and i checked the P CON MAIN fuse and its also okay, and replaced the gear selector switch (electromechanical unit connected to gear assembly) and nothing changed and the issue remained, can you please support.
    #1 M.Aqrbawi, Sep 1, 2016
    52,863
    how many miles/km on her? have you owned since new? any accidents?
  3. M.Aqrbawi
    Jordan
    it have 10000 miles only and had a front end accedent, any way this problem started to happen lately i think its not related to accedent.
    52,863
    there is a pdf on c2310, have you seen it on line?
  5. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Check this article:
    https://techinfo.toyota.com/t3Portal/document/rm/RM1290U/xhtml/RM000001U8W004X.html?sisuffix=ff&locale=en&siid=1472749548244
  6. M.Aqrbawi
    Jordan
    I am sorry, the code i have is C2311.
  7. bisco
    52,863
    do you have any vermin that might chew on the wiring?
  8. Zahid Bhatti
    Zahid Bhatti New Member
    Pakistan
    I have Prius 2010. Now facing the same P Lock error for the past few weeks. After reading all the above threads, i also replaced my battery but that evil P error is still there. Even the replaced battery is perfectly fine. I have also get it checked quite a few times but that P error is now getting on my nerves.
    I have also tried to remove the 7.5 fuse from the switch box but P error is still there.
    Whenever P error appears, I simply apply the parking brake and turn the vehicle off. After 5 minutes wait, i turn it on the vehicle and every back to normal like nothing would had happened.
    Please help me out. May i need to replace that 7.5 fuse or connect some cable between the 7.5 fuse to blue wire. Or what.
    If anyone know the permanent solution of this problem, please do let me know
    Let me reiterate that 12V battery is perfectly fine.
    Please HELP.
    SOS
