Cabin air filter part number
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen2prius, Aug 11, 2022.
  1. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    The air filters are due to replace, both engine and air conditioning filters.
    I found the part number of engine air filter: 1780121040.
    For some reason can't find the part number of air conditioning filter, the filter behind glovebox.
    I called the parts department, they quoted AU$45 for engine air filter, but $90 for air conditioning filter!
    Anyone has the part number? I need to look around for a more reasonable price.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    There are several Toyota part numbers for the cabin air filter on second-generation Prius cars:
    • 87139-28010 is for model years 2004–2009 (Japan), and 2009 only (Europe, Australia, etc.)
    • 87139-47010 is for model years 2004–2009 (U.S.) and 2004–2008 (Europe, Australia, etc.)
    • 87139-47020 is an optional “deodorant & pollen filter” (Japan and U.S.)
    In the U.S., Toyota offers local substitutes: 87139-47010-83, 87139-YZZ19 (standard electrostatic), or 87139-YZZ03 (premium charcoal).
  3. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    Thank you, was able to find one from an interstate Toyota supplier using your information, much more reasonably priced. :)
    #3 gen2prius, Aug 12, 2022
    Elektroingenieur likes this.
  4. Mendel Leisk
    42,362
    How do they look?
  5. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    Quite dusty, I changed the engine air filter 5 years ago, at the time I didn't change the air conditioning filter, I think it was never changed.
  6. Mendel Leisk
    42,362
    Ok. Yeah it's just sometimes people feel obligated to change them due to the schedule, when they're still viable.
  7. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Fram makes that filter The Gen 2 and the Gen 3 the Gen 3 is different I'll have to go look for the part number for the Gen 2 and they're only like $9
  8. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    Unless they are the exact OEM spec, 3rd party filters are sometimes not as effective, maybe for cost reasons or maybe for performance, they are sometimes not as dense or as thick. Probably ok if to be renewed regularly.
    The car was under a service plan for the first few years, the invoices were not itemised so I am not 100% sure if the a/c filter was ever changed. It is the same filter since the service plan has ended, so I think I should use an OEM one after all these years.
  9. bisco
    52,878
    i use the oem charcoal filter. tried a few aftermarket, and they didn't fit well.
  10. Tombukt2
    13,868
    2,520
    Durham NC
    The fram poly filter fits my tray perfectly and there are other ones you can buy and trim to fit they're not pleated in other words there's other filter material that you could trim and lay on the tray too that could be endless. I use the fram pleated Walmart has it it's like $11 generally when I buy them. They fill up with junk so fast stuff runs down the plastic under the wipers down the tray even acorns can roll right down on top of the filter so usually once a week I try and remember to swing the glove box down just pull it out knock it off put it back in.
  11. gen2prius
    gen2prius Member
    98
    28
    Sydney, Australia
    i-Tech
    I think that's a good strategy, clean it regularly before the contaminants get a chance to go inside fibre materials.
  12. Tombukt2
    13,868
    2,520
    Durham NC
    Yes and when the seasons change I make it a habit to not be under the trees that all the crap falls out of like the squirrels eating the acorns and all that type of residue The leaves don't so much make it through the tray but the pieces of acorns little nuts tiny sticks and all that will drop right on that filter like it's made to catch them and it fills up fast One thing it does help with those it keeps the leaves and little pieces from getting into the fan and sounding like your bicycle wheel with cards clothes pinned to them remember that is kids right
