Cabin air filter
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Ookies, Jun 17, 2017.
  1. Ookies
    Ookies Junior Member
    Chicago Burbs
    Anyone know what fits for the cabin air filter? Is it the same as other prius?
    iPhone ?
  2. Mendel Leisk
    38,728
    Probably. You could ask at the dealership parts counter; they would know.
    Is the air really that bad over there? Lot of diesels and coal burning? :eek: On the west coast of BC, we're at 68K km's and 7~ years, still on both original filters.
  3. GLouderback
    GLouderback Member
    Lower Merion PA
    They are the same size as the 3rd gen Prius but comparing the two, there is a difference, but not in size. If you have some left over filters, I would use them.
  4. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    How do you change it? The original place inside the glove box is fixed with several screws.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, the original place was -behind- the glove box, not -in- the glove box. But not having a Prime, I can't look. Buy me one and I'll check. ;)
    DonDNH and Prius from Dad like this.
  6. GLouderback
    GLouderback Member
    Lower Merion PA
    Take out the glove box completely first.
  7. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    You might try the manual. Page 620 for my advanced. "Replacing the cabin air filter". It has been in the manual of each generation of the Prius sold in the US since at least 2005.
    Mendel Leisk and CaliforniaPrius like this.
  8. Carl M
    Carl M New Member
    Vermont
    Dimensions are almost the same, but the pleats in the filter run at right angles to the standard Prius'. There is a tab in the Prius Prime filter carrier that prevents the Prius filter from seating. I've had to buy a replacement from the dealer. Wix and Fram listings for Prime just list the same number as for the Prius.
    The air's not bad here, but the mice are. I'm still trying to cover all the entrances to the ventilation system with hardware cloth. So far Mice 2, me 0.
  9. GLouderback
    GLouderback Member
    Lower Merion PA
    Sounds like you need a few cats
  10. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Have you looked at the Gen 4 filter? It is likely the same.
  11. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Mice, they can be a real problem.
  12. Andyprius1
    2,327
    859
    Cool CA
    Is there a poisonous mouse feed? Now that I’m in a rural area I also have to keep a lookout.
  13. Mendel Leisk
    38,728
    I've heard they'll eat poisonous feed, then crawl back in the car to die. :(
    Also, maybe too risky: birds get into it, all sorts of critters?
  14. Garmy
    Garmy Junior Member
    68
    Why do mice love the Prius? I had to set traps in my 2012 and caught 2. This car was always garaged!
  15. bisco
    49,500
    the wiring insulation is plant based, very tasty.
  16. bisco
    49,500
    i took over 50 mice out of the house last year. this year, i called an exterminator and he placed bait traps in the garage and basement. so far, so good.
  17. DavidA
    2,328
    1,812
    Chicago western burbs
    50? :eek:
    Beats my 27 one year high total. Our two cats got at least half of those with the rest caught in the old fashioned snappy traps (placed outside the reach of cats - don't want to hurt my hunters).
  18. bisco
    49,500
    i know, right? we've been here 13 years, and that was high. it wasn't even a bad winter.
    if the poison doesn't work, there's a company that claims they can close up the entry points. i expect that to be expensive.
  19. Mendel Leisk
    38,728
    The one thing I don't you think you can close up is the engine bay, too many openings at the wheel wells.
    One thing you can do though, The engine air intake looks like a perfect hamster run, with a cozy air filter box at the end. I recently installed this;
    MrBugMan, Prodigyplace and Mark57 like this.
  20. DavidA
    2,328
    1,812
    That looks like a meat grinder input funnel.
    Mark57 and Mendel Leisk like this.
