Cabin Filter Button
Discussion in 'Gen 3 Prius Main Forum' started by El Dobro, Sep 8, 2011.
  1. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    LOL that's sort of what it looked like to me all this time. I think I'd hit it once or twice before and couldn't realize what it did.
    I did use it yesterday while behind a school bus. It kicked my fan speed from 1 to 3 bars and took about a minute to clear the smell from the car after I turned from behind the bus.
    I think I should go check my cabin filter though, as it's been about a year since I replaced it. Same with the air filter. I knew I forgot to do something when I did that oil change a month ago.....
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've found you can't use that button when in defrost mode though given the hard fresh intake requirement. If you want clear windows, you'll have to put up with the smell.
  3. El Dobro
    El Dobro A Member
    7,093
    3,271
    Yep, pretty much any car will shut off recirc mode when you put the front defroster on.
  4. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I didn't know we had a cabin filter either! So, on the bottom row of buttons below the display screen, is it the button to the right of the MODE button? I thought that button just switched between the different vent configurations (air just blowing thru the floor vents, or just thru the dash vents, or air blowing out all the vents)....
  5. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Yes, that is the cabin filter button. It shuts off automatically after a while. I probably used it 2 or 3 times in the 1+ year I had my Prius. I never remembered it was there unless I got behind a diesel truck or bus in traffic.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    As was explained earlier in this thread, the cabin air always goes through the filter.
    The outside air option runs 100% out side air through the filter
    The recirculate option is mostly recirculate cabin air with about 10% outside air for safety purposes. It all goes through the filter.
    The filter button cuts off all outside air for 3 minutes and once again, all air is run through the filter. It's useful when you get stuck behind a diesel truck, pass a dead skunk or a politician.
    The airflow, recirculate or outside, is controlled by a big servo control flapper valve located just before the filter in the airflow stream.
    The Toyota shop manual has some diagrams that show component locations.
    2 people like this.
  7. El Dobro
    El Dobro A Member
    7,093
    3,271
    I don't remenber which one, but one of the auto manufacturers calls it a cabin sweep button. They said it's to give the cabin air a good cleaning to take out pollen etc., then you use the system as normal.
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Toyota calls it a Dust and Pollen mode button, to remove dust and pollen from the cabin air.
  9. El Dobro
    El Dobro A Member
    7,093
    3,271
    It was something like Nissan or Honda that called it a cabin sweep button.
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    The one that looks like ) :: (
  11. Nirmalanow
    Nirmalanow New Member
    23
    Arizona
    We just got a 2011 Prius IV and it has a "Plasmacluster" ionizer that cleans the air for three minutes. The button is in the same place.
  12. RRxing
    RRxing Senior Member
    2,558
    1,832
    NEPA
    From the New Car Features: "The Plasmacluster generator produces positive and negative ions from the water molecules (H2O) and oxygen molecules (O2) in the air, and emits them into the air. These ions reduce airborne germs."
    The ions are discharged from the driver's side vent continuously whenever the AC button is lit. There is no separate button to turn the Plasmacluster on or off.
  13. GoldPianoGarden
    841
    74
    98
    Brunswick, GA
    Hmmmm, I wouldn't mind having that on my car. I have horrible allergies, and I'm ALL FOR anything that would help purify the air I'm breathing inside the cabin. I wonder if we can upgrade our "regular filters" to do that... I miss that feature from my Infiniti FX45 I recently owned. That was some great air inside the cabin of that car. Out of the dozens of cars I've owned, I'd have to say that it was the most near-perfect combination of everything that I could want in a car. Except for sucking gas! lol
  14. RRxing
    2,558
    1,832
    NEPA
    The Plasmacluster is a separate component located behind the driver's side vent. It has nothing to do with the cabin air filter, which is located behind the glove box.
  15. rosenberger31
    rosenberger31 New Member
    Austin
    I wonder if there is a way to keep the "air filter" button engaged for longer than 3 minutes. I'm in the car for 2.5 hrs a day and most cars on the road here in Texas seem to have the worst exhaust.
  16. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    No and it's not safe or a good idea to have 100% recirculation for an extended period of time.
  17. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Please explain.
  18. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Without being refreshed, the oxygen within the cabin is quickly depleted. I've found on a Summer's day with four of us in the car, I'm sleepy within minutes of turning on recirculation. A constant supply of fresh air is a crucial safety feature.
  19. fotomoto
    5,639
    3,815
    So. Texas
    How quickly?
  20. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    If you mean just regular recirculation, I doubt you're experiencing a lack of oxygen. The regular recirculation on any car is never 100% recirculated; it's probably around 10% fresh (similarly, the fresh air setting is usually recirculating 10 or 20% of its air, to reduce load on the heating/cooling system). The "micro dust and pollen filter" may go to 100%, I'm not sure - I seem to recall reading that once, but I don't see it in either the service manual or the owner's manual.
    You inhale about 8 liters of air in a minute. 21% of the inhaled air is oxygen, and 16% of the exhaled air is oxygen; so you use .05*8 = 0.4 liters of pure oxygen per minute. The Prius's interior volume is 93.7 L (passenger area) + 21.6 L (cargo area) = 115.3 L. At 21%, that means it contains 24.2 L of pure oxygen. It'd take 60.5 person-minutes (e.g. one hour for one person, or 15 minutes for 4 people) to consume all of that oxygen. Realistically, you can't go down to 0% oxygen; down to about 10%, most people will still be functional (though impaired), or at 15%, you'd probably only notice if you were doing strenuous activity. So you can consume 6% (or about 7 L) before you'd start to notice; that'd happen in 17.5 person-minutes.
    BUT, the car is not sealed. I'm pretty sure more than a few of us have spent more than 5 minutes in a closed, unventilated car with 3 friends and not noticed a lack of oxygen, as the math might predict. In the summer, it might get uncomfortable due to heat and humidity, but not due to lack of oxygen.
    To avoid smelly exhaust, I'd recommend just using regular recirculate; on the (hopefully rare) occasions where that isn't enough, hit the filter button for an extra boost.
