Cabin Filter Button
Discussion in 'Gen 3 Prius Main Forum' started by El Dobro, Sep 8, 2011.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's 80% recirculation (20% outside air).
    It does go to 100% recirculation for 3 minutes, along with higher fan speed.
    It's not just a lack of oxygen that's dangerous, but a potential small leak of the exhaust system leading to a buildup of carbon monoxide inside the car.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    OK, so fifteen minutes for all of it. Did you subtract the volume of the passengers and cargo from the available air volume within the car? How long until the driver starts to notice a difference? I know I'm more alert with a steady supply of fresh air, especially on a long family trip in the Summer. Based on my experience, I'd say it's not safe to leave the system in recirculate for more than a few minutes - Toyota says three.
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Doesn't anyone read their manuals? I know it's a point of pride not to read computer manuals and work it out for yourself and the prius has lots of little computers but the manual actually has important and informative stuff. :rolleyes:
  4. Tideland Prius
    16,665
    Believe it or not, the filter button is one of the things that isn't described in detail in the manual. IIRC, all it says is it's the "dust & pollen filter" button. This is confusing because it'll lead some people to believe that the filter isn't in use unless you press the button when in reality, all air that comes through the vents pass through the filter behind the glovebox.
  5. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    Does any other Toyota have a "filter button"? If not, why was it decided this was a feature that would be appreciated by Prius drivers and not by everyone?
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Lexus has it and I'm sure other flagship Toyota models have it as well but I don't know the specific models off the top of my head.
  7. HarryStamper
    HarryStamper Junior Member
    Naperville, IL
    Lest anyone worry too much about oxygen depletion, the passenger and cargo volume (93.7 and 21.6, respectively) units are in cubic feet, not liters.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    small but important correction: Prius volume (and all other EPA car volume #) is measured in cubic feet, not litters. One cubic feet contains ~28L.
  9. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Heat and humidity here in Texas makes the use of recirc especially effective. I keep it on nearly all the time in the summer. My longest non-stop drive with the a/c in recirc mode is 6 hours on I-10 (Van Horn to Kerrville) before my bladder finally said "give!". After the bio-break, got back in and drove another 3 hours home.
    By your count, I should have died/passed out hundreds of times. It's a car not a sealed spacecraft. ;)
  10. El Dobro
    El Dobro A Member
    7,102
    3,282
    I'll bet you cheated by putting a window down every few minutes. :p
  11. fotomoto
    5,639
    3,815
    So. Texas
    OK, you busted me! Yup, I pulled over every 3 minutes to lower the window since I didn't want to risk inhaling any exhaust fumes either. Trip actually took several days..... :p
  12. markabele
    5,084
    1,782
    Nebraska
    So you pressed the "air cleaner button" every 3 minutes for the whole drive?
  13. parnami
    parnami Member
    227
    48
    Recirc mode is NOT the same as pressing the filter button!
  14. Hank101
    Hank101 Member
    108
    SC
    What button?
  15. fotomoto
    5,639
    3,815
    So. Texas
    LOL, no. I have used the air-recirc feature my whole life and lived to tell the tale. The "you'll run out of O2 if you leave the air-recir on" is a myth.
    I use "the air cleaner button" if I'm stuck in smelly traffic (diesels) or skunk, etc. It only functions for about 3 minutes and then returns to your previous settings (very convenient).
  16. fotomoto
    5,639
    3,815
    So. Texas
    The ICON is not intuitive. I originally thought it was just a label for the air conditioning panel and not a button at all. It's the one located between the "mode" and "a/c" buttons and has a person sitting with an arrow pointing at the head.
  17. El Dobro
    El Dobro A Member
    7,102
    3,282
    It will be well used during hay fever season.
  18. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    The argument here is whether 100% recirc for too long is dangerous. Given that 20% fresh air is still let in when you're in normal recirc that's moot.
  19. GoldPianoGarden
    GoldPianoGarden Bling Meister
    841
    74
    98
    Brunswick, GA
    I feel the same way. I never had any clue that button was some filter button for the air in the car until I accidentally ran across this thread one day!
  20. ArkiePrius
    ArkiePrius Junior Member
    68
    Arkansas
    I never knew what that button was either, although I have pressed it before, until reading this thread. I have read and reread the manuals, guess it is just one of those things that you overlook. I continue to learn little unknown facts almost every day on this board.:rockon:
    Arkie
