Cabin Filter: Original vs. Fram Fresh Breeze
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Jan 5, 2011.
  1. peterjmc
    917
    189
    Clarksburg, MD
    Air flows downward. So the arrow should be pointing to the floor.
    Nexus 5
  2. maestrosteve
    maestrosteve Junior Member
    Toms River, NJ
    It's amazing that I should see this post now. My Prius is only a few months old so I didn't buy it for this car, but I just bought this filter a few days ago for my other car, a 2010 Subaru Legacy and had the same issue that you are having. The directions and video for installing that filter in my car says to install it with the arrow pointing DOWN, yet the filter I took out plus the filter cover both say to install it with the arrow pointing UP. I posted the question to Fram on their Facebook page 3 days ago. They didn't answer right away, but when they got back to me, I didn't feel confident in their response that they really knew the answer, but they told me to go against what I saw in the video, and go against what I read in their instructions, and install it with the arrows pointing UP.
    As far as looking at the old filter to see which side was dirtier to give me a clue of air flow - I couldn't tell. Both sides looked hardly dirty at all, and looked pretty equal. The last time I changed that filter was 30K miles ago.
  3. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    My understanding is that the Toyota filter (I have not seen the Fram filter) is an electrostatic filter i.e. part of its filtering mechanism is to actively attract and hold particles by static electricity. It is not just a fine mesh that physically blocks lumps (but it will do that as well) but much more sophisticated than that.
    It should only need a light vacuuming and then a gentle rinse in clean water to remove particles and reactivate the mechanism.
    I am sure it has no function to remove smells. Anything added to the electrostatic filter will reduce its efficiency.
    Perhaps a piece cut from a cooker hood filter and placed in the holder under the ordinary filter will remove those smells as these are usually activated charcoal to remove grease and smells, they are also cheap, I must try some time but it will reduce airflow perhaps to an unacceptable level.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I found an explanation here:
    http://legacygt.com/forums/showthread.php/diy-cabin-filter-change-2010-210720.html?t=210720
    Some filters have an arrow and "UP" on them. Using those you would point the arrow UP. Some have an arrow for airflow direction which do not have the word "UP", and for those you would point the arrow down.
    You must live in an area where the air is very clean. I've changed one in our '04 Sienna and it looked bad. Lucky you....
    The Fram Fresh Breeze supposedly has baking soda as well to help neutralize smells.
  5. El Dobro
    El Dobro A Member
    7,086
    3,263
    Looking at both sides of a cabin filter makes me wonder what difference it makes which side you place up, they both look the same.
  6. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Maybe they look different under a magnifying glass? :unsure:
  7. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I remember the Prius User Manual mentioned about the air flow direction. If your replacement filter has arrow indicating the air flow direction, one should follow it. Like jzchen says above, there may be a difference on the two surfaces but human eyes can't tell.
  8. tharepairguy
    tharepairguy New Member
    This should be no different than HVAC filters. Lesser the surface area, the more current needed to push the same amount of air through it. The cheap pleated filters have been known to be VERY hard on blower motors in the HVAC world.
  9. princessprius
    princessprius Junior Member
    50
    baking in the southwest
    For our house, the pleated Allergan trapping filters were rather expensive, and THOSE are very hard on the HVAC system.
    It's the cheap ones without the pleats that don't overtax the system.
    Tough cause we have allergies...
  10. El Dobro
    El Dobro A Member
    7,086
    3,263
    At home, I use the cheapo ones for the Winter months and the pleated ones during the warmer months, when the furnace isn't in use.
  11. toyolover
    toyolover Member
    441
    67
    toronto, canada
    When you say "current", do you imply air flow? Isn't it a fact that when you have more pleats, you have more surface area. When you have more surface area, you are blocking more air flowing through (at the same time trapping more dust.)
    So why are you saying the cheap pleated filters (usually with less pleats) is hard on the blower motors? Shouldn't it be easier on the motor but trapping less dust?
    princessprius likes this.
  12. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    No. Think of the filter as a nozzle. The more pleats give more surface area, so other things, being equal, the opening of the nozzle is larger.
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    When I started being brave enough to change the filters on my own, I started using FPR 9 because that was the highest Home Depot carried. Then I found that they started carrying FPR 10 and started using them. Costs me about $40 every 90 days for the two that we need, quite a pain in the pocket! I think with all the pollution in the air our lungs deserve it though. When the HVAC does come on I notice they look quite concave. Kind of l0oks like it might all of a sudden be sucked into the tube...
  14. pmike
    pmike Member
    237
    81
    Central Florida
    If your grill with take it try one of these instead: Return Air Grille Filter at Filters Fast
    I only change mine once a year. I use a HVAC vacuum gauge and its not even close to needing to be changed after a year: General G-99 Air Filter Gauge Kit - Amazon.com
  15. princessprius
    50
    Our HVAC system can't handle the FPR 9, so I tried a lower allergen filter, and even that is too hard on it.
    We have to use the totally cheapo no pleats, which don't help our allergies.
    The coil on the outside unit would freeze and the system would labor to keep the house cool when using the expensive, pleated filters.
    This is on a brand new house, crappy builder HVAC maybe.
