Cabin Pre-Conditioning: Problem with A/C Using EVSE
Discussion in 'Prime Main Forum (2017-2022)' started by Oniki, Jun 10, 2017.
  1. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Thanks for the data point -- I'll try the same on my car out of curiosity but I would not choose use that method voluntarily since it entails leaving the windows closed, or standing around for 3.5 minutes after I close the windows until the A/C Fob function is active.
    #21 Oniki, Jun 22, 2017
  2. eluo
    eluo Member
    123
    71
    Commack, NY
    Looks like you can get the dealer to program your windows to close automatically when holding the lock button.
    Not sure if you still need to wait 3.5 minutes. I'm guessing not, since car was never started using this method.
  3. Oniki
    Oniki Active Member
    652
    500
    Colorado
    Hi Eluo,
    This option is mentioned in the owner manual but I'm pretty sure it is not available to the base ("plus" in the US) trim. I'll double check again to be sure
    priuscatprimeguy likes this.
  4. Tideland Prius
    16,678
    The remote closing of windows is not available in the U.S.
    We have 3 options
    1. Remote open
    2. Key-in-door open
    3. Key-in-door close.
  5. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    If the ca is locked I used E-tune app to start a/c prior driving off while plugged to evse - worked every time regardless if the car competed charging or not. Fob key did not work for me. for some reason while plugged I can't start A/c that way.
    BTW
    preconditioning the car while plugged in can gain as much as 3 miles of EV range in hot climate (read Houston in my case), so I start using it regularly.
