Cabin smells like engine cleaner 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JJNY, Jan 11, 2023.
  1. JJNY
    JJNY Junior Member
    24
    16
    NY, NY
    I have a 2010 that I bought two months ago. When I test drove it, it smelled like engine cleaner. The kind that is oil based, so probably k1 and solvents in it. Anyway, I have used these products and know they take some time to air off the VOC etc... However, two months later after many round trip trips of 5 hours each way, I still have this smell. Any thoughts?
    It is also worth mentioning that I had a strong gas smell as well for some point. I underfilled the tank and it seemed to help. Then, I filled it all the way up and the issue doesn't seem so obvious. I did notice the fuel cap appeared wet when this issue was presenting. It has me thinking crud or insects in the evap system? It might have blown out/freed up.
    Perhaps they are two unique problems, but maybe they are connected.
    Anyone have any ideas? It isn't the battery rubber stink issue. Definitely the engine cleaner smell that it you have ever smelled, you know it is kind of unique.
    Thanks!
    AltraStache likes this.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Try replacing your cabin filter. Once the odor gets in the filter, its hard to get rid of. Next I would definitely get your gas cap and tank checked out. Doesn't sound safe to ignore.
  3. JJNY
    JJNY Junior Member
    24
    16
    NY, NY
    I replaced the cabin filter, it didn't improve, but it did get ride of a half pound of acorns... fuel smell isn't there anymore.
  4. Mendel Leisk
    41,911
    Have you popped the hood? Wondering if the oil filler cap might have been forgotten, for one. Don’t ask me how I know.
