calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Miles...Gallons....MID Mpg.....Calc Mpg...Difference
    435....... 8.93.........50.0.........48.71.......3%
    406....... 8.37.........51.1.........48.51.......5%
    429....... 8.93.........50.6.........48.04.......5%
    312....... 6.26.........52.5.........49.84.......5%
    It's frustrating that the discrepancy increases with the displayed mpg (I was getting 3-4% difference when the readouts were in the low 40s). I still haven't broken the 50mpg barrier with this car!
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    306.0 miles / 6.544 gals / 49.9 mfd / calculated 46.76
    323.5 miles / 6.040 gals / 55.9 mfd / calculated 53.55
    alfon
  3. afstudio
    afstudio New Member
    San Rafael, CA
    I have had my 2110 Prius for 2 months and I'm hovering around 40mpg. I drive mostly short distances. Is this the computer or the car? Anyone know?
  4. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Are you hovering around 40 mpg for the entire 2 months? Or when you reset one of the trip meters and measure for a few days do you never get much over 40 mpg? Big difference.
    You should be able to get 50 mpg on some trips. But when starting cold and driving 1-2 miles if you get 30-35 you are doing well. You should be able to start cold (for CA) and drive 6-7 miles at 35mph without a lot of braking, and get 50+ mpg.
    3PriusMike
  5. Tideland Prius
    16,673
    ok I filled up today and I'm rather shocked at the difference.
    4.4L/100km vs. 4.79L/100km (MFD/Calc'd)
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks Roy. Post #5 on CleanMPG.com really clears things up for me and explains why I was seeing what appreared to be many "fresh off the boat" Prius' getting a large discrepency in computer vs. calculate MPG and why some of the newer owners with later build cars are not seeing such large swings.
  7. driv3r
    driv3r New Member
    Romania Baia Mare
    Hello to everybody on the forum. I have a question:
    The prius sold in EU is rated at: extra urban 3.8/ urban 4.0/combined 4.0 (L/100km with 17" wheels) .. so how is the average calculated? it shuld be 3.9 right?
    Exemple: Toyota IQ EU engine 1.0l 5MT: extra urban 3.9/ urban 4.9/combined 4.3 (L/100km) how?
    European Urban cycle=4km; Extra-urban cycle=7km
    So... (4km x 4.0l/100km + 7km x 3.8km)/11km=3.8727/100km... ??
    For the IQ: (4x3.9 + 7x4.9)/11=4.536.. witch is close to 4.3 combined but not quite.
    Any thoughts on this?
  8. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Last fueling today, reported 4.9L/100km, calculated 5.44L/100km, that is, about 9% more.
    Previous ones were:
    - 5,1L/100km vs 5,48L/100km (7%)
    - 4,7L/100km vs 4,65L/100km (-1%)
    - 4.9L/100km vs 5,2L/100km (5%)
    - 4,9L/100km vs 5.03L/100km (3%)
    That is, averaged, 4,6% more than it actually is. Considering that at the pump, on average, they cheat, saying that you bought more fuel than what actually gets into the tank (how much on average, I don't know - I would guess 1-2% more) - I would say that the predictions of the Prius are quite accurate. I don't think other cars report fuel consumption any better than this.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You did read the part about Toyota putting in a 6mpg offset on the first batch of cars and up to a 3mpg offset on later cars right? :)
    Read post #5 again: 2010 Prius-III P&G, SHM and WS FE techniques rehashed, defined and refined - CleanMPG Forums
  10. CPSDarren
    CPSDarren CPS Technician
    533
    112
    Chicago
    3200 miles now. Computer has generally been 55-56 on every tank of 500 gallons. Actual has been 2-3mpg less than the computer.
  11. codybigdog123
    codybigdog123 Got Mad and Left in a Tizzy
    239
    29
    Chicago, Il
    Got my Gen III in August, and since then, have put 2,200 miles on the vehicle. I have never gotten below 50 mpg - on the computer, or measured. My measured mpg is typically 3 mpg lower than what I read on the computer.
  12. codybigdog123
    239
    29
    Chicago, Il
    Until the car warms up in the first few miles, the mileage is typically lower than the EPA estimate of 50 mpg. But anything over a couple of miles, unless you are running the car in very cold weather, your mpg's should begin to climb. Another factor that will drive the mpg down is the grade of the road you are driving on. Finally, if you operate in the PWR mode, or are rapidly accelerating every chance you get, yes, your mileage will be less than 50 mpg.
    But in my 2,200 miles of driving since buying the Prius, I have NEVER gotten less than 50 mpg. Prior to the gas stations putting in 'winter blend" gas into the pumps (lower mpg than in the Summer), I use to get in the high 50's, and more than a few times, into the low 60's mpg - per tank of gas.
  13. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    after 7370 miles
    Computer average = 46.76 mpg
    Manual calculation = 44.83
    Prius V
    Gasoline costs: $0.059 / mile
  14. SAYLAVI
    SAYLAVI New Member
    WIND SWEPT PRAIRIE
    After 3558 miles ... computer = 50.4 mpg / calculated =48.0 mpg
  15. nooaah
    nooaah New Member
    380
    Philadelphia
    So far the computer has been about 1mpg lower than calculated.
  16. jbedi
    jbedi New Member
    26
    sf bay area
    After 6073 miles, calculated mpg equals 52.3, computer indicates 53.9.
  17. sdleo726
    sdleo726 New Member
    98
    San Diego
    First refill at 390.2 miles, FCD - 47.2mpg, calculated - 45.4mpg, filled up with 8.588 gallons of regular unleaded.
  18. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Ken,
    I made edits to the original post to help out.
  20. tidefan
    tidefan New Member
    Florence
    The terrain really matters!! We live in where the terrain is rolling and not flat. Our mpg's vary between 46 and 48.5, which is still fantastic. This week we are spending the holidays in Perdido Key, Florida which is FLAT. Last tank calculated out at 53.5mpg. The FCD read over 56mpg. NICE IMPROVEMENT!!
