calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Update:
    6/14/10 / 384.5 miles / indicated 49.5 / calculated / 47.632
    6/20/10 / 289.5 / 51.8 / / 49.554
    6/27/10 / 346.1 / 55.1 / / 53.131
    6/28/10 / 286.9 / 58.3 / / 56.823
    For some reason the average for the last four tanks is under 2 MPG discrepancy. It use to run around 3 MPG.
    The last tank with 286.9 miles, when my wife and ,took a trip from Seaside Oregon to Cabelas in Lacy Washington. Via Hwy 30 from Seaside to Interstate Hwy 5 to Lacy Washington.
    Temps were in the low to high 60's on average. Speeds were from 55 to 70 mph with at least 40 miles, maybe more, on cruise at 71 MPH indicated, probably 70 MPH true, on Highway 5 were the legal speed limit, in some areas is 70 MPH, for passenger cars.
    I was really suprised at 56.8 MPG, that was round trip so everything is equal. Also only 1.5 mpg off the computer.
    Impressed, considering we were only getting in the mid to high 40's MPG(calculated) a few months ago.
    alfon
  2. PixelRogue
    488
    86
    US
    Hello everyone,
    I noticed that the calculations from the dash are clearly not the reality at the gas tank...thrilled to see others posting on the topic.
    According to the dash, i'm getting 52mpg on average.
    According to the math, I'm getting 43mpg on average.
    Would be really happy of the 52mpg were real, rather disappointed with the 43mpg.
  3. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    2-3 MPG, consistently across the first five tanks.
  4. hlunde
    hlunde Member
    419
    75
    I recently did a drive of about 1400 miles and like others, I noted that the displayed MPG was a couple percent more than that calculated based on gasoline purchase.
    What I'm thinking is that Toyota calculates fuel delivery based on injector delivery only, while ignoring the fuel vapors delivered to the engine via the closed evaporation system for the gas tank. If the tank is well ventilated so that vapors are continuously removed from the tank, then perhaps evaporation delivery is significant. This would be the case for all vehicles, but it's just more apparent when fuel consumption is so minimal.
    For example, if I'm only using one gallon per hour, then each 1.28 oz. evaporated per hour would make a change of 1% in calculated mileage.
    The "additional" delivery from gas tank vapors would not affect combustion since oxygen senors would compensate.
  5. ledd4u
    ledd4u Junior Member
    28
    I am a new owner and have about 1700 miles on th car and the most I have seen is 45. Also, my battery never reaches 8 bars? Does the car gave to break in? I drive mostly in ECO mode.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    O7/05/10
    106.8 miles / 1.846 gals / 58.0 indicated / 57.854 calculated
    mostly highway 35-60 MPH /
    weather 75 degrees / sunny and dry
    AC on about 20% of the time.
    Three of us in the car plus fishing gear, cooler etc.
    alfon
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    That seems waaaay off. I've put a little over 5000 miles on my car and the displayed MPG and the calculated MPG typically differ by 2 - 3 mpg.
    Is the 52 vs 43 based on one tank? Lifetime of the vehicle? A one time event or consistently off by 11 mpg?
  8. Chris Franks
    Chris Franks Junior Member
    austin texas
  9. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Over the last 21 tanks, I've gotten the following discrepancies (+ is higher than actual, - is lower than actual):
    +4.3%
    _____
    +1.6%
    +5.3%
    +5.7%
    +7.8%
    +4.2%
    +2.9%
    +5.2%
    ______
    +1.6%
    +6.1%
    +4.3%
    +5.1%
    +5.6%
    +4.2%
    +1.1%
    +6.3%
    +4.6%
    +5.3%
    +5.0%
    You can't really average the percentages, but an eyeball says its around 5% high overall. With my year-long average of 48.24 MPG, that yields an average of something like 2.4 MPG too high.
  10. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    first 3,500 miles on March 2010 production is Prius says 61.2 mpg, Pump says 59.5 mpg or Prius reads 1.7 mpg high. Ted
  11. skm009
    skm009 Member
    132
    Ohio
    First fuel-up!
    48.1 Calculated
    48.5 Computer MPG
  12. blisspacket
    blisspacket Junior Member
    32
    StAugustine FL
    We've got 12k miles on our type 2. Flogging I95 at 70-78 consistently gets 40 mpg calculated. AC on, cruise on and using hand speed control. I don't look at the instrumented mpg stuff.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    What does your screen say? We are looking to gather information on any discrepancies between the computer readout and hand calculations. :)
  14. EddietheK
    EddietheK New Member
    Philadelphia
    I just updated my spreadsheet with a bunch of gas receipts I was accumulating in the upper glove box of my Prius built June 2009 and find I have complete figures on 18 tanks full of gas. The difference between the spreadsheet calculated MPGs and the Prius calculated MPGs varies between 1.3 and 3.1 MPG per tank full. That is, the CONS value of the on board display is 104% to 109% of the actual hand calculated value. I do mostly city driving and these numbers are based on getting only 34-39 MPG in a tank full. It concerns me that my mileage is so different from what everyone else appears to be getting. I'm not an aggressive driver. I practice pulsing and coasting, etc. When I questioned the service manager about this where I bought my car, he said I should drive faster! I'm thinking I might have a lemon. I'm wondering if anyone else has experienced such low city mileage.
  15. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Note:
    31,000 miles on our Prius.
    Michelin Energy Saver Tires/ 195x65x15 with 44 psi max pressure
    in all 4 tires, Costco Nitrogen.
    Over 20,000 miles on tires.
    Oil, 0x20 Valvoline Synthetic / 4 quarts only / so not over filled
    245.9 miles / 4.716 gals / indicated 52.8 / actual 52.141
    225.9 miles / 4.020 gals / indicated 58.1 / actual 56.194
    both tanks filled on 07/25/10
    last tank, 56.194 mpg / highway driving only, 55-70 mph with AC
    on 70% of the time. outside temps / ranged from Seaside Oregon
    57 degrees / to our destination, Lacy Washington, 88 degrees
    alfon
  16. vtht65
    vtht65 New Member
    Virginia
    Through 13916 miles I recorded 294.115 gallons: 47.31 mpg. Displayed MPG before fill-up was consistently in the 51-52 MPG range. Best was an actual 436 mile trip @ a displayed 59.1 at fill-up was an actual 55.7. There is clearly a display error of ~6% better than actual. That seems excessively high to me.
    One wonders whether the fuel mileage software has a customizable calibration parameter.
    If not, it should.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I agree it should.
    Between what people are reporting and what Ken said about his Toyota source, is looks like there is an intentional 5% optimistic error in the system.
    If you consider that there are station pump errors (usually very small), driver top off differences and plain old human error, I'm guessing that if Toyota were set it 5% more pessimistic, then most of them could be about right +/- about 1%.
  18. kramtrebor
    kramtrebor New Member
    Okay, 11,500 miles, I get only 37 computer, 35 manually checked. I have a 2010 Prius IV, I live in south Florida and use the A/C all the time. The dealer says there is nothing wrong and I have to learn how to drive a Prius. This is my 3rd Prius. I know how to drive it. Any suggestions.
  19. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    My experience is Honda was +8% and VW was +10%.
    I think Toyota is also watching other car numbers.
    Are there any cars which have the calibration capability?
    Ken@Japan
  20. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
