calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Miles driven: 362.7
    Gallons used: 7.078
    Computer Generated MPG: 54.1
    Calculated MPG: 51.243
    Weather 45-55 degrees roads wet
    at times. Typical damp,rain, cloudy
    NorthWest Oregon conditions in the winter spring.
    With summer, dry roads, temp in the 65-75 degree
    range MPG Calculated would be at least 55-57 MPG's.
    alfon
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    301.8 miles / indicated 59.2 mpg
    Fuel used: 5.228 gallons
    Calculated MPG: 57.727
    90% highway / temp avg. 55 F/ filled up
    at about Sea Level / up to elevation of 1,640 ft / over
    Hwy 26 Sunset Hwy to Portland OR /
    Filled up again at Sea Level
    Roads: Dry
    Speed 40-65 MPH
    Cargo. two adults
    Gas: Costo Brand / Regular / 10% Ethanol / Ethanol
    is required all year long in Oregon
  3. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    I filled up my 2004 498 times. The average difference between calculated and MFD was 0.232 mpg with the MFD on the high side. I'd say that's pretty accurate.
    My 2011, with 10 fill-ups so far, shows the MFD value high by an average of 2.8 mpg. Every single fill-up has shown an error to the plus side by the MFD. Minimum of 1.3 mpg to a maximum of 4.5 mpg error. This is on every single fill-up. There are no alternations like you would expect if inconsistently filling up the tank.
  4. ralphgonegolfing
    ralphgonegolfing Junior Member
    17
    Canton, Ohio
    Last 2 times I checked mileage after fillup 3 weeks
    part on 5/18/2011 drove 416 miles and it took
    7.004 gallons 59.49 miles per gallon I was amazed
    As car was only showing 54 Mpg. 3 weeks ago it took just under
    7 gallons and averaged 57.6 and the car showed around
    52.5 so I thought I had made a mistake on the
    Calculations. Anyways I rechecked my numbers saved on my I phone
    And they were correct - I am elated
  5. DaYooper
    DaYooper Member
    106
    Sout of da UP eh!
    Last tank, drove 479 miles, took 9.61 gallons for a 49.8 calculated mpg. The MFD said 53.0 mpg.
  6. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    My last fill up, 434 miles, pump 8.46 gallons for 51.3 mpg. The MFD read 53.4 mpg
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    278.6 miles / 5.058 gal's
    MPG Indicated 58.6 MPG
    MPG Calculated 55.081 MPG
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I have noticed that in the last couple of weeks, a big
    difference in MPG's.
    Roads have been for the most part dry, and temps in the mid 50's, as opposed to temps in the mid 40's with wet roads.
    Last fillup, yesterday.
    Miles 134.6
    Gal's: 2.280
    MPG : calculated 59.035
    Indicated: 61.8
    Gas: reg unleaded, 10% Ethanol, no choice, in Oregon it is
    a 10% Ethanol State reqired by law all year long....
    If it was not for the Ethanol MPG's would have been over 60 MPG.
    alfon
  9. RJay
    RJay New Member
    Northwest INdiana
    Took delivery on my 2011 Prius on April 11. After the first fillup I brought the tires up to 44/42, no other mods. Using 10% ethanol, 87 octane gas. 1,568 miles total. Overall, the indicated mgp is 54.1, the actual measured is 51.7 for a 4.4% difference. Individual data from 4 fillups:
    Miles: 371 Indicated: 50.7 mpg Measured: 49.1 mpg Diff: 3.2%
    Miles: 341 Indicated: 55.8 mpg Measured: 52.4 mpg Diff: 6.0%
    Miles: 431 Indicated: 56.3 mpg Measured: 53.9 mpg Diff: 4.3%
    Miles: 425 Indicated: 53.9 mpg Measured: 51.5 mpg Diff: 4.5%
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Just my opinion but during the summer it appears the mpg guage
    is more accurate than in the winter.
    Has anyone else have a similar theory?
    alfon
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Miles: 504.3
    Gals: 9.595
    MPG Guage: 56.1
    Calculated: 52.558
    10% Ethanol Regular gas
    Mixed driving/ two trips up the Sunset Pass Hwy 26
    from sea level to 1,640 feet.
    al
  12. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    You might want to read this post.
  13. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Total Miles: 1582
    Gal's used: 29.239
    Average MPG indicated: 57.96 ( 5 fillups)
    Actual MPG calculated: 54.1058
    Gas: Regular with 10% Ethanol
    alfon
  14. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Miles: 405.2
    Gals's used: 7.657
    MPG Computer: 55.3
    MPG Calculated: 52.91
    Gas used: Costco: Regular Unleaded with 10 Ethanol
    Summer is better in a Prius......
    alfon
  15. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Miles: 566.4
    Gallons used: 9.167
    Calculated mpg: 61.8
    HSI mpg: 65.4
    HSI/calc MPG: 1.058 = 5.8% discrepancy = enough to be really annoying. Why can't Toyota get this right, when they got so much else about the Prius right??
    Gas: Shell regular (probably has some ethanol in it)
  16. Insight-I Owner
    505
    100
    Essex, CT
    So 4.5% discrepancy.
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    It does vary sometimes as much as 4 mpg off and as little as 2 mpg
    I agree, Toyota could calibrate the MPG guage do read down say 3 mpg that would give a more accurate reading.
    My ex-girlfriends 2006 HOnda Civic Hybrid was alway off by about 1-2 mpg in the negative. If the guage read 51 mpg calculated would be 52-53 mpg consistently.
    alfon
  18. Insight-I Owner
    505
    100
    Essex, CT
    Over 60,000 miles, my Insight-I's computer reads 0.5mpg higher than hand calculated, 84.3 vs 83.8mpg, which is 0.6%. That's about 10x more accurate than the Prius-III. If Honda can do it accurately, why can't Toyota? From what I read here, the Gen II Prii did not have this problem.
  19. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I'm starting to get convinced that some of my MFD error is caused by leeway that the gas station has in overbilling me.
    One gas station gives me around 4% and another gas station consistently gives 6% error. I need more fillups to test this theory, but so far it is a trend.
    For instance, pumping at Costco gives less error.
  20. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Miles: 345.8
    Gals: 6.639
    MPG Guage: 55.0
    Calculated MPG: 52.086
    Gasoline: Regular Grade with 10% Ethanol
    Driving: normal mix, city and highway, one trip
    from sea level to 1642 feet, Hwy 26 Sunset Pass,
    and back to sea level, Seaside Oregon. Also
    another trip with 5 full size adults in the vehicle, Vehicle Weight
    3,950 lbs loaded.
    Impressed with the MPG as no other U.S. available car comes
    even close.....
    Took a look at a Smart Car yesterday, why do they call them smart?
    Tiny car with only room for two and a cheeseburger. MPG is only 35-38 mpg and Premium gas is required.
    alfon
