calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    As a long-term weighted average, actual=0.956 of indicated mpg, very consistently.
    #1201 CR94, Nov 8, 2017
  2. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    That's what I'm getting for our 2014 Prius-IV at just under 40K miles.
  3. Mendel Leisk
    42,343
    61 pages of consistent inconsistency, @Prius Team ?
    bentbow and jerrymildred like this.
  4. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Yes,car to càr. An individual car should be consistent. Some owners have trouble with the math to get a true average,
  5. Mendel Leisk
    42,343
    My error dances around a bit, but settled in on 7.5% positive bias. Wayne Gerdes had a pre-production fourth gen for testing, and he found the displayed mpg virtually identical. But owners of (production) fourth gens are reporting more-or-less the usual positive bias, IIRC.
  6. Jim7
    Jim7 Junior Member
    western mass
    That's been my experience for the last 90,000 miles (we took over our daughter's lease at 45,000, have 142,000mi on it now). If I show 48mpg on the computer for example, it's about 45.5 - 46 actual, or right on the money. In winter of course it's less, we're in the NE.
  7. Mendel Leisk
    42,343
    My latest tank is a highwater mark in inaccuracy. Maybe pump ran on a bit, I'll see if it balances out on the next:
    Feeling the effects of colder weather, short trips and snow tires too I guess.
  8. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    After 78,000 miles, the indicated MPG averages about 6.55% too high, bouncing around quite a bit.
  9. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    I've been tracking display bias across a 2004, then 2007 Prius for over 13 years. Here's the data: [​IMG]
  10. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Mine is ~8% too optimistic Vs reality
  11. danpriusman
    danpriusman Junior Member
    Pensacola
    I have been tracking the mileage and found that there is a consistent 6-7 mpg difference. The computer will calculate 54 and I get 48 after fill-ups. From reading other posts most people get greater than 50 mpg with their Prius. I drive in a very conservative manner using hypermiling techniques where available. Does anyone else have lower numbers?
    thanks
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Welcome, Dan. Quite a few people here get similar numbers. Here are the stats for the Prius on Fuelly.com. Average for the 2010 is 45.3 mpg.
    RMB and Mendel Leisk like this.
  13. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I found that it varies if, when filling up, you stop when the pump shuts off, or if you top-it-off. I always stop when the pump shuts, just to keep it consistent. But I, like others here, have the same discrepancies between what the read-out states, and my own calculations at the pump.
  14. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    I also drive a diesel bmw. The estimated consumption from the computer is spot on
    The car's ecu knows EXACTLY how much fuel it uses
    So the displayed mpg is purposely wrong, to make drivers happier!
  15. Steves895
    Steves895 Member
    48
    68
    Concord, NC
    Filled up today, display indicated 59.9, Fuelly calculated at 57.5.
  16. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Please what foes the LIFETIME MPG mean?
  17. Mendel Leisk
    42,343
    For me, it's all the gas I've put in, divided into all the miles traveled. Well, I'm doing liters per 100 km, but same thing. Also, I didn't track the first 2154 kilometers, but I've stuck with it since.
  18. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Thanks a lot!
  19. Bob L
    Bob L New Member
    Illinois
    I have a 2013 Prius. My figuring my mpg on my own versus the car computer generally shows the car computer overestimates to my calculations about 2-4 mpg.
  20. Bob L
    Bob L New Member
    Illinois
    I have done this about 20 times. Also, mpg is much worse the colder it is.
