calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. bdc101
    bdc101 Member
    250
    usa
    First tank: dash says 41.0, actually came out as 42.5.
    Second tank: Dash says 44.1, actually came out as 41.3.
    Both were topped off. Total average is 41.8 since I bought the car and fixed the HG.
    The second fill may have been a little bit more topped off. Either way, I am spending about $5/week on gas, so I feel pretty great. (Coming from driving a 2003 BMW X5 gas guzzler.)
    I am getting a set of snow tires later today and taking it on its first highway road trip since I bought it and fixed the head gasket. Looking forward to having a long trip under its belt and seeing the highway mileage.
    ASRDogman likes this.
  2. Mendel Leisk
    42,343
    What was the miles on it? Have you also cleaned the EGR circuit?
  3. bdc101
    bdc101 Member
    250
    usa
    I am at 263k now, and yes I had it cleaned in the ultrasonic tank until it was sparkly.
  4. Outdoors68
    Outdoors68 Junior Member
    Sarasota FL
    At 246k and average around 45-46mph still, a nice tailwind and some back country roads and I can hit that 50mph they talk about;)
  5. Bill Norton
    Bill Norton Senior Member
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    "it" ?
    Which parts did you clean?
    The intake manifold is the important part because it is the part that makes the individual port flow uneven.
    jerrymildred likes this.
  6. wezzdc
    wezzdc New Member
    San Francisco, California
    I'm only getting 30-35mpg even with conservative driving habits. Could this be an indicator of a bad battery? How else can I troubleshoot this issue.
  7. Mendel Leisk
    42,343
    Calculated or displayed? For how long, recent drop? What’s the miles on it? Any recent maintenance, or new tires? Change to driving patterns, trip length, conditions, speed?
    addendum: just noticed your other posting, regarding hitting a curb, air bags deployed and so on. Seriously, you’ve got major fish to fry, and need pro to assess.
    #1327 Mendel Leisk, Nov 26, 2025
  8. wezzdc
    wezzdc New Member
    Haha indeed. This was before hitting the curb so was always trying to figure it out.
    To reply, it was displayed as 35mpg. Been like this since I bought it at 160k miles. It's running on same old tires and this is the observance after several 100-200 mile rides to outdoor parks driving at 65mph or so mostly on the highway in summer weather.
  9. Mendel Leisk
    42,343
    Calculated (aka actual) mpg is typically ~7% less with 3rd gen.
  10. ASRDogman
    ASRDogman Senior Member
    8,065
    4,086
    Many things can cause lower mpb. Tires, inflation of tires, driving habits..... certainly a hybrid
    battery that is getting weak. A weak 12v battery....
    Perhaps using the Prolong system to "renew" it. It certainly helped me
    get another 100,000 miles out of mine.
    Calculated mpg and actually mpg will never be exactly the same. Both are estimates.
    Even if you use the same pump and fill up at the same time under the same conditions you'll never
    fill up to the exact same spot every time.
    My calculated is usually 1-2 mpg higher than my actual mpg. But it's close enough.
  11. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Same for my new Gen5 LE.
  12. Mendel Leisk
    42,343
    Gen 5 Toyota apparently knocked off the 7% BS factor; previous gens were notoriously “optimistic”.
    VelvetFoot likes this.
  13. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    I have been tracking my mpg with the Carfax fuel tracker and it has been spot on and not even 1 mpg difference from what the car display is showing.
    Matches the miles I get out of a tank.
    410 miles driven = 41 mpg
    395 miles driven = 39.5 mpg
  14. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    My MPG display has only a 4.5% "BS factor," not including an additional ~1.1% odometer exaggeration factor with my present tires, so about 5.6% overall..
    Bill Norton and Mendel Leisk like this.
  15. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    My experience with standard-tire-equipped Gen 5 and European cars is that the difference isn't percent, but a certain mph delta over the entire range.
  16. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I thought id find a post like this as a sticky. I am getting confusing readings myself. The dash says 34.5 Cons MPG and 14.4 Average MPH which doesnt seem accurate. When I filled up my tank the range calculator said the tank would last an estimated 500 miles which would indicate 50 or so MPG and also matches the estimated MPG of 50.4 shown on the dash when you turn the car off.
    Is there a way to reset the CONS MPG and Ave MPH counter? They appear to be off because im def getting way more than 34 mpg.
  17. ASRDogman
    8,065
    4,086
    Disconnecting the 12v battery for 30 minutes or so will reset the reading to default.
    Then as you drive it learns your habits and will calculate the mpg.
    PriuSocal likes this.
