Calculating EV Range
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Nov 27, 2012.
  1. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    PiPLosAngeles, you mentioned in one of your posts "ICE-assisted starts from traffic lights." If that is the case, then I don't think you can call it pure EV. If you try it again, how about going slow enough on the take-offs from signals so as not to engage the ICE? Some others have posted EV only miles in the low twenties. My personal best is 17, with the norm being 14 to 15, and a couple of times I've hit 16. If the ICE kicks on at any time, I consider that the end with regard to actual EV only miles.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, traffic lights, another variable (time at light, time coasting to light, etc, etc)
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    agreed
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    On my trip to work my EV range is 11.9 miles. (in the summertime) at 35 mph with four traffic lights 2.7 miles one way. Jurassic test was 1438 kg curb weight. 57 kmh (35.4 MPH) 2.7 KWH battery point A to point B 4.3 km (2.6 miles) Range 17 KM (10.56 miles)
  5. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    If you read closely you'll see that was for the remainder of the 21.3-mile commute AFTER the EV ran out at 20 miles. In EV mode the ICE doesn't run until you exceed 62 mph or so, even from traffic lights.
    I apologize if the way I worded it made it confusing. When I wrote: From there the rest was downhill coasting and a couple of ICE-assisted starts from traffic lights, the "from there" meant from where I ran out of EV. Using Google Maps it appears that the exact mileage to that point was 17.9, so I apologize for stating it was 20.
  6. mrbigh
    3,686
    699
    Long Island, NY
    Every millimeter counts for EV range :rolleyes:
    lensovet likes this.
  7. rogerv
    1,639
    317
    OK, having read it again I understand. What some people do is reset the trip odometer and see how it compares to the estimated EV range. I don't do that, but rather make note of the reading, including tenths, on my "trip a" odometer. Of course, my actual range includes some regen from braking and slight changes in elevation, coasting to red lights, etc.
  8. lensovet
    2,615
    496
    Burlington, NJ
    I'm pretty sure the issue here is that you are using the average "traveling" speed as opposed to the actual average.
    What happens when you put in the actual average for the whole EV portion of the trip?
  9. PiPLosAngeles
    1,551
    724
    I don't know the actual average for the EV portion of the trip because the trip meter reads for the whole trip. The last mile is severe traffic on surface streets with top speeds around 10 mph. I wish I knew how to take snapshots of the trip meter at a certain point without trying to use a camera while driving.
  10. bisco
    52,862
    for the purposes of this discussion, jurassic park is probably fine for ev only trips.
  11. PiPLosAngeles
    1,551
    724
    The whole reason for this discussion is the mismatch between Jurassic Test and real-world results.
  12. lensovet
    2,615
    496
    Burlington, NJ
    Siri? Lol
  13. rogerv
    1,639
    317
    I keep an eye on the trip meter and the EV estimated range, especially when the latter is running low. That way I know how far I've gone on EV only for that particular trip.
  14. PiPLosAngeles
    1,551
    724
    That's what I used to think. Today I learned the ICE can still turn on in EV mode.
  15. bisco
    52,862
    check the sticky, len put in all the reasons why ice can start in ev mode.
  16. rogerv
    1,639
    317
    Right, but then the EV light goes out to indicate you are in HV mode. Like I said in an earlier post, if that happens the test of EV only range compared to the EV range estimate is over. For me, it's only a little game to see how much surface street driving I get out of a charge. If I'm heading for the freeway, I switch over to HV ahead of time. When I'm returning home after a freeway drive, I switch to EV for the last ten miles or so, and stay under 62 mph the rest of the way. For some reason, when I do that, the next day the EV estimated range will be up after charging. Like I said, for me it's just a game, although I love getting the fantastic overall mileage this car gets.:)
  17. lensovet
    2,615
    496
    Burlington, NJ
    No, not quite. The EV car icon will turn into an outline, yes, but the green EV mode light right next to the speedo will NOT go out if the engine starts. This is trivial to check – while in D and with your foot on the brake, floor the gas pedal. ICE will kick on but that EV mode light will stay on.
  18. PiPLosAngeles
    1,551
    724
    The part I don't understand about the trip was that the ICE was certainly not on for a couple of miles. I'd bet my PiP on that. It wasn't even on for a couple of minutes because I watch that display like a maniac. The ONLY clues I ever had was that one single bar on the 1-minute consumption graph was a hair shorter than all the others, and even then it was only down to 80 or 90 mpg, and that the trip MPG was 400 instead of 999.
  19. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    That's not entirely correct. If you get into the PWR range of the HSI in EV mode, the ICE will run.
  20. lensovet
    2,615
    496
    Burlington, NJ
    Actually, you can see 100+ mpg even with the ICE on in EV mode. The only reliable way to see whether ICE is on is to look at the EV car icon in the middle of the "power bar" on the HSI. If you have a car with an outline, ICE is on. If you have a green-filled car with the letters EV inside it, then ICE is off.
