Calibrating the Nav.
Discussion in 'Gen 3 Prius Technical Discussion' started by katiesdad7, Nov 9, 2012.
  1. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    Is there a way to calibrate the nag? It shows me in the wrong city. Or do I need to take it to the dealer?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    If it shows the wrong city, check and make sure it is set up for the correct region. This is the most likely issue. If you know the region is correct then you need to take it to the dealer.
