Calibration Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Techars, Jul 22, 2017.
  1. Techars
    Techars Junior Member
    17
    Denver
    A friend of mine has a 2005 Prius and this morning we were checking the status with the TIS Techstream software. When we ran the health check the software returned a number of Calibration ID's. Specifically:
    • Engine and ECT - 34705200
    • Hybrid Control - 899834712301, 899814707001, 899814707002, 899814711001, and 899814707004
    • HV Battery - 898904708000
    Is anyone familiar with what a Calibration ID is and what these numbers refer to? Would it be safe to assume they're a reference to some manufacturer specific calibration sections / procedures / bulletin? Vehicle isn't exhibiting any problems and it doesn't appear these calibrations are critical to the operation of the vehicle.
    Regarding the HV battery...two years ago we replaced a couple of the individual cells and reading the live HV battery data shows the battery appears to be in great shape. Could we need a calibration because we replaced a couple of the cells?
    If something needs to be calibrated to bring it back into peak operational condition it might be something she'd want to do.
    Thoughts, comments, suggestions? Car has 183K miles on it.
    MMtec likes this.
  2. Patrick Wong
    18,212
    6,529
    The calibration ID is like the software version of a particular ECU. Leave those alone unless you have a licensed copy of Toyota Techstream.
  3. Techars
    17
    Denver
    Thanks Patrick. It sounds as if there is nothing that needs to be done and I will leave these alone.
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I would not say that....
    The calibrations are CAREFULLY tailored software programs for each module and they ARE CRITICAL to the proper operation.
    Short answer is no. Longer answer is that the software calibration *may have* been updated by Toyota since the vehicle was built, but just as with Win 2000, Vista, 8..., newer is not NECESSARILY batter ;)
    Based on multiple PC members, seems like off-board charging/equalization is the best bang-for-the-buck.
  5. Techars
    17
    Denver
    Thanks all the feedback on this. The take away is to leave them alone and that's just what I'm going to do.
