Calibration Updates (ECU Flash) policies in different markets
Discussion in 'Gen 3 Prius Technical Discussion' started by astrand, Jul 28, 2013.
  1. astrand
    astrand PHEV Guru
    33
    Linköping, Sweden
    It wonder if the policy for Calibration Updates (ECU Flash Reprogramming) is different for different markets. For example, I've noticed that if you run Techstream configured for the US market, it is possible to automatically search for new updates directly from Techstream. Calibration Update files for US and Canada can also be downloaded directly from https://techinfo.toyota.com, provided that you have a subscription. All in all, seems to be quite easy and straight forward. But how often are these updates actually performed in practice, anybody in the US that knows?
    In Europe, or at least Sweden, things looks different. First of all, Techstream is not used at all (!). Instead, The instruction says that the Intelligent Tester II should be used. It does not say how the calibration files can be retrieved. I get the impression that since the procedure is fairly time consuming, such updates are not performed very often. The EU tech site,
    Toyota Service Information
    , does not provide any subscription which can access calibration files. I've been driving Prius for many years now, both gen 2 and gen 3, but as far as I know, my dealer has never updated anything. Anybody else living in the EU that has got an update?
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Most come in the form of a TSB. Otherwise, it's a manual search.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Pearl S only goes to the stealer if there is a recall. So far that hasn't happened. So no updates.
  4. Former Member 68813
    3,524
    981
    US
    US dealer will not update firmware unless there is a major reason such as warranty problem with TSB fix.
    robertmaria likes this.
