Featured California APPROVES Aftermarket Catalytic Converters!
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by fullylaced1, May 3, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,439
    2,402
    Taylors, SC
    I did exactly what you did and bought this one;
    Catalytic Converter For 2012 2013 Toyota Prius V 1.8L EPA | eBay
    It's cheap insurance. And, it will still be worth that much, if I don't use it. It's like a spare tire or a fire extinguisher. It will have been worth it if they were never used and thrown away after its service life.
    Given inflation, the cost of materials and shipping, the cat will likely be worth more in the future.
    jzchen likes this.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Wow. Interesting I did not know that. I have experienced incompleteness before regarding headlight mounts. (Yes apparently Toyota engineered, for at least the LED headlights that I’m aware, weakened headlight mounts so they’d snap before you damage your expensive LED lights). But you need to find the replacement mounts. parts.toyota.com was incomplete regarding those mounts for me….
  3. Trollbait
    12,501
    I assumed the plan was getting the out of state cat installed before inspection.
  4. Georgina Rudkus
    3,439
    2,402
    Taylors, SC
    He would be much better off if he installed the non-C.A.R.B. compliant cat after the next smog inspection. Then, he would be complete safe with the cheap cat for nearly two years.
  5. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Yes, my apologies, my initial wording said that my cat was already stolen but no it's still intact. Just contemplating getting a spare like a spare tire.
    moto g(7) power ?
  6. privilege
    privilege Active Member
    659
    169
    Birmingham
    please read my post again.
    I was suggesting that the straight pipe only be used to drive out of state and have an aftermarket cat installed.
    it would be pretty dumb to show up to a California based inspection with a straight pipe.
    jzchen likes this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Ahh. Thought I'd bump the thread as MagnaFlow now has a v CA cat, for a whopping $2805 though...
    moto g(7) power ?
  8. Rmay635703
    Rmay635703 Senior Member
    2,667
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    Aftermarket more than OEM
    Terrific
  9. Georgina Rudkus
    3,439
    2,402
    Taylors, SC
    That means it's more important protect your cat to keep it from getting stolen.
  10. WebVixen13
    WebVixen13 Junior Member
    Indeed. I just researched all of this today, at first exuberant that CA had finally approved an aftermarket for Prius.
    My senior mom's 2009 Prius had its catalytic converter stolen in February. She had bought it 2.5 years prior, with help from me... for 6k. Because finances have been tight, she didn't think she'd need comprehensive insurance on an older car. We were super naive, and didn't know about catalytic converter locks/shields either.
    Now she's without a vehicle, with arthritis in her knees. :( Used car prices have also sky rocketed by thousands in the past few months, so I haven't been able to find her a replacement (my help is limited, I have some savings but not enough in the current market).
    We've had the Prius parked at my sister's for months (maybe even getting chewed on by rodents). Because the estimates we had gotten for the Toyota oem replacement were $3k and higher, which is half what we paid for the whole car or more.
    I can't believe the aftermarket is more expensive!!! We had been told months ago, that the Toyota one was around $2200. Which seemed egregious at the time.
    It's super depressing, because if I spent that much on the 2009.... what if another expensive part goes out? Like the hybrid battery or the transmission?
    I was hoping to get her an easy to fix 2013 Corolla, but prices are literally 2-3k higher than a few months ago on private sales of them!
    We're in a lose/lose situation with this.
    Rmay635703 and bwilson4web like this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    There are some non-CA catalytic converters that are much cheaper. It may be worth a shot.
    $1871.xx from Puente Hills, through parts.toyota.com, a lot cheaper than the comparable MagnaFlow.
    moto g(7) power ?
  12. hill
    8,790
    Seller has over 6,000 prior transactions - & still maintains 99.6% customer satisfaction. You don't get NEAR that much at your local service station.
    jzchen likes this.
  13. El Dobro
    El Dobro A Member
    7,086
    3,263
    The cheating software was tied into the steering angle sensor. ;)
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    There's recent news about 1B Euro fine of BMW and VW for being an "emissions cartel"! I guess they didn't learn their lesson?! As my son's friend would say: "Gangsters!"
    moto g(7) power ?
  15. El Dobro
    El Dobro A Member
    7,086
    3,263
    Diamler was fined, too.
    jzchen likes this.
  16. privilege
    659
    169
    Birmingham
    WHY not replace your cat with a straight pipe... then put it back on for inspection ?
    jzchen likes this.
  17. hill
    8,790
    worth noting? Ever wonder why we don't hear of Volt Cat's being stolen? With your Gen1 Chevy volt avatar - the cat (on both Gen1 & Gen2 Volts) is located just after the manifold. Seem nuts? Cat's work only after they heat up - & close to the manifold works to speed up that goal. Then, being in that location deep in the engine compartment, it's nearly impossible to remove it. Skumbab crook would have to jack up the car - remove aero panels underneath - reach up to saw the base ... then not be able to reach the top. Poor dumb crook.
  18. bwilson4web
    16,187
    They really have a problem with my 2019 Std Rng Plus Model 3.
    hill likes this.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    That’s a possible solution, replace the Prius with a Tesla. (Albeit an expensive solution. How many cats can one get with the price of a Model 3? )
  20. privilege
    659
    169
    Birmingham
    why don't you have a straight pipe put on, drive out of state, have aftermarket cat installed, drive back ?
