California Electrical Grid Sources
Discussion in 'Environmental Discussion' started by iplug, Jul 11, 2016.
  1. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    On our current PG&E rate plan for the 6 "summer" months, during peak hours and in the second of two tiers, we are charged 45.7 cents/kWh.
    We picked this plan intentionally, however, as we over generate during this time so we actually get credited at that rate. Saves us ~$1000 a year.
    It's pretty easy to charge our two cars at night and run the pool pump, washing machine, dryer, dishwasher, whole house fan, etc on the cheaper off hours.
    52,807
    what do you pay off peak? we don't have tiers, so there's no incentive.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I don’t pay anything until the true-up, which is next May;).
    So the monthly bill is now $10 for the privilege of being connected to the grid:).
    Not a bad deal (y).
  4. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    We are grandfathered in to the E-6 rate plan which is the best for solar users with a decent sized system with electric vehicles.
    We pay as "little" as 17.9 cents/kWh for off peak in the first tier in the summer and 18.4 cents/kWh for off peak in the first tier in the winter. Off peak jumps up about 8-9 cents/kWh for the second tier.
    Even though these base rates are expensive, we consume most of our electricity on the off peak hours and sell lots of excess back on the pricier peak hours.
    So it is possible to be a net grid consumer by a significant margin, but owe nothing except the connectivity charge.
  5. bisco
    52,807
    complicated. what would someone pick using 200kwh/mo. and no solar, and what would the rates be?
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If you use our old rate plan as an example (think it was called E-1 SB residential), they use your baseline at $0.21 / kWh for tier 1 and tier 2 is $0.27 / kWh.
    So if our allowance or baseline is 11.2 kWh per day, they’ll multiply the number of days by 11.2 and establish the billing cycle baseline. If you exceed the 11.2 per day, you’re in tier 2 and in higher tiers is it is another multiple above the baseline.
  7. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Having a hard time figuring out their tariff page on this. Lots of math depending on specific location and baseline kWh allocation.
    Most people are on the E1 rate plan by default who have no solar. No daily time of use, but tiered and summer and winter rates. In our area, that's and unbundled rate of 13.8 cents/kWh for the first tier in the summer and 11.2 cents/kWh for the first tier in the winter.
    With all charges it looks like about $0.21 /kWh for the first couple hundred kWh then $0.28/kWh for the next few hundred, then quickly gets to $0.43/kWh.
    So in your scenario, maybe only about $40-45 / month. But remember, this is California and you will need the AC in the summer unless you live near the coast or way up in the mountains. My neighbors who have no solar have told me they typically pay ~$600-1000 each for the two hottest summer months. Houses range maybe 2200-3200 sq ft.
    bisco and Raytheeagle like this.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Outbhere in Solano County they also have “flex days” which from the hours of 2-7 PM they charge something like 4c the normal rate in days the temps climb above 100 F:cool: . They have 15 of those days alloted a year and and are required to give one business days notice and can’t have them on the weekend.
    Let’s just say our 3,000 square foot house was in the high 80’s to low 90’s those days to avoid a bill the size of what @iplug is referring to;).
    So the solar array we installed will make putt house more liveableduring the summer (y).
    iplug and bisco like this.
  9. bisco
    52,807
    at least you have expensive gas to make plug ins worthwhile.:cool:
    iplug and Raytheeagle like this.
  10. bisco
    52,807
    i think i would have a small room with a window a/c unit and a bed for those days, or sleep in the prius.:p
  11. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Very true. Now we just need to buy one ;).
    Still our 2010 Prius averaging 50 mpg and the RX450h averaging 30 mpg far beats most of the people out here. Plenty of folks soloing to work in their pickup or urban assault vehicles:cool:.
    Arco has gas at $3.47 a gallon today for regular. Could be worse(y).
    Starship16 and bisco like this.
  12. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    It's nice to drive clean vehicles and conserve gas & oil. But in my humble opinion, here in Southern California I believe t's even more important to cut back on water usage and electricity as much as possible. Especially water. The officials have been warning us for years... and it falls on deaf ears.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Agree completely ;).
    Up here we still have cut our watering back and slowly working on installing drought resistant landscaping :).
    Plenty of water being used right now to contain the yolo county fire that’s already consumed 88,000 acres and is only 25% contained:cool:.
    Pyros and fireworks out here are a terrible mix:mad:.
  14. bisco
    52,807
    couple things i noticed when i was out there in the nineties. people complained about the price of water, but it was much cheaper than here.
    also, poor lawn sprinkler installations everywhere i went, with water running everywhere.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Some have their sprinklers poorly aligned :(.
    Some have them running at 4 PM:confused:.
    Some water 2-3 times a day:eek:.
    So the awareness is low:cool:.
    Probably some things are the same 20 plus years later:oops:.
  16. fuzzy1
    10,691
    Net metering in my state involves both a net billing meter, and a solar gross production meter. The later is a requirement to get the state's solar production incentives, so that data exists here.
    There is very little reason for anyone in my state to skip out on the production incentives.
    #36 fuzzy1, Jul 4, 2018
  17. fuzzy1
    10,691
    From what I've seen, it seems that some cities have done a very good job of controlling per-capita water consumption, down to around the 50 gallons/person/day range. But others needed to be dragged in the modern era of finite supply, kicking and screaming about having to give up their old birthright to unlimited, unmetered cheap flat-fee water service. Sacramento (the city, not the legislature) was a serious example of the later, where in the midst of the most recent drought, half the city was still unmetered. And their plan to fix it was a multi-decade, half $billion roadmap, designed to be delayed and deferred.
  18. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    It's that time of year again, so here's the annual update on the California Electrical Grid.
    Another great year for California, continuing to lead in grid greening. Please note that for 2018, we came off a record rainfall 2017 year which briefly inflated hydro sources.
    2018 California Electrical Grid Source data:
    Total System Electric Generation
    Highlights comparing 2018 to 2017:
    (note units are percent total system power)
    -coal mix is decreasing and only 3.30% (vast majority remains imported)
    -natural gas use increased after being down for 3 consecutive years, now 34.91% of the power mix
    -nuclear remains nearly stable, at 9.05%
    -large hydro decreased from 14.7% to 10.68% (2017 had record rainfalls within CA)
    -non-large hydro renewables grew and continue to climb rapidly, continuing a long trend, with a year-over-year 2.36% increase in the share of total power mix, to a current level of 31.36%
    -wind continues to grow with new accelerating gains following some years of slowing increases, now 11.46%, up from 9.4%, briefly retaking the renewable lead from solar which took the lead for the first time in 2017
    -solar (1 MW and larger facilities) increased to 11.40% (10.2% last year)
    -small hydro fell as with large hydro as 2017 had a temporary burst with record rainfall that winter/spring
    -still, the impact of solar above is greatly underestimated as “behind the meter” (BTM) home solar is not measured as only units generating 1MW or greater are counted; “BTM residential solar generation was estimated to be 13,582 GWh, a 20 percent increase from 2017”; therefore California probably gets ~17% total system electric generation from all sources of solar PV
    -California total system electric generation was down 2 percent from 2017 and a major factors cited wereenergy efficiency programs and residential installs of BTM residential solar PV systems that directly displaced utility-supplied generation.
    -California's non CO2 emitting electric generation categories (nuclear, large hydroelectric, and renewables) accounted for 53 percent of its generation, compared to 56 percent in 2017. As a result, in-state generation dropped by 6 percent (11,494 GWh) to 194,842 GWh. This decrease was due, in part, to reduced generation from hydroelectric power plants as dry conditions returned to the state. Net imports increased by 6 percent (4,944 GWh) to 90,648 GWh, partially offsetting the decline.
    Raytheeagle and tochatihu like this.
  19. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Report came out even later this year (released earlier this month); here's the annual update on the California Electrical Grid.
    2019 California Electrical Grid Source data:
    2019 Total System Electric Generation
    Highlights comparing 2019 to 2018:
    -coal mix continues to decrease and only 2.96% (vast majority remains imported)
    -natural gas use resumed its decrease (was downtrending but spiked to 34.91% of power mix in 2018), now down to 34.23%
    -nuclear remains nearly stable, at 8.98%; almost 2/3 of this is from the Diablo Canyon in-state plant, currently scheduled to be decommissioned in 2025
    -large hydro increased from 10.68% to 14.62%
    -non-large hydro renewables grew and continue to climb, continuing a long trend, although slowing the rate from the prior year, to a current level of 31.70%
    -this was mostly due to a decrease in annual wind production, down from 11.46% to 10.17%; in 2018 wind briefly retook the renewable lead from solar; solar had taken the lead for the first time in 2017 and has now resumed the lead
    -solar (1 MW and larger facilities) continued to grow robustly, increased to 12.28% (11.40% in 2018)
    -still, the impact of 1+ MW solar is greatly underestimated as “behind the meter” (BTM) home solar is not measured as only units generating 1MW+ are counted; for some reason, there was no update in this report - the 2018 report noted “BTM residential solar generation was estimated to be 13,582 GWh, a 20 percent increase from 2017”; at that time California probably received ~17% total system electric generation from all sources of solar PV, higher now
    -California total system electric generation continues its downward trend, down 2.7 percent, or 7,784 GWh, from 2018; previously major factors cited were energy efficiency programs and residential installs of BTM residential solar PV systems that directly displaced utility-supplied generation.
    -California's non-carbon dioxide emitting electric generation categories (nuclear, large hydroelectric, and renewables) accounted for 57 percent of its generation, compared to 55 percent in 2018. As a result, in-state generation increased by 3 percent (5,633 GWh) to 200,475 GWh. This increase was due, in large part, to increased generation from in-state large hydroelectric power plants, up 11,049 GWh (50 percent) from 2018. The gain from hydroelectric generation was offset by a 15 percent decrease in net imports to 77,229 GWh, down 13,418 GWh from 90,647 GWh in 2018.
    #39 iplug, Sep 12, 2020
