California: ENRON then, renewables today
Discussion in 'Environmental Discussion' started by bwilson4web, Jun 9, 2016.
  1. bwilson4web
    16,524
    Source: Excess solar power in California? Pay Arizona to take it
    It’s just after lunchtime on the trading floor of Arizona Public Service (APS) in downtown Phoenix, and three guys are parked in front of screens, watching the ever-fluctuating price of power. They are chasing deals, not so much here in Arizona, but in California.
    “That’s very typically what happens every day during this time of year,” said Brad Albert, who is in charge of resource management for APS, the state’s largest utility.
    It’s a mild, sunny spring day in California. Customer demand is low, but solar panels are churning out lots of power. So much, in fact, that California has a surplus at the moment.
    As a result, prices have gone negative, and the Arizona utility is actually being paid to take some of that power from its next-door neighbor.
    This dynamic is “very much driven by the large amounts of renewable generation, particularly solar in California,” Albert said.
    I am remembering the ENRON frauds that drove California into brown-outs and excessive prices just 15 years ago.
  2. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    It's a good problem to have. I suspect this is the true reason why the big utilities in California are wanting to get into the public EV charging business. They want to get tens of thousands of charging stations installed at workplaces and shopping areas in order to absorb all of the growing daytime solar output. I think we will start to see daytime time-of-use rates that are off-peak during the day in addition to overnight.
    Bring. It. On.
  3. hill
    9,023
    There goes all the gloom & doom'ers claiming too many Chademo & Supercharger stations will cause the grid to collapse. In another vein, we have Tesla's power-wall manufacturing ramping up for storing our new excess. Talk about great timing . . . .
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Last I heard CA is expecting possible brownouts this summer due to lack of nat gas for power, due to the nat gas leak incident outside LA.
  5. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Really, things like this demonstrate why grid storage is so necessary nowadays.
    It's also worth noting that grid storage isn't just in batteries. Thermal storage can be an incredibly cheap way to get a form of storage (by time-shifting demand) onto the grid. Although it's not scaled down to residential scale yet, commercial buildings are already using ice generation AC systems to shift load to off-peak times. And, then, there's hot water storage - while tankless hot water heaters are more efficient in terms of watt-hours of electricity per gallon delivered, a large, well-insulated tank water heater can reduce overall carbon footprint of the grid by using renewables to heat the water when they're available, and storing the hot water for later, to avoid using inefficient fossil-fueled peaker plants.
  6. fuzzy1
    10,694
    For electrics, tankless water heaters are terribly INefficient compared to heat pump water heaters. Especially so in warm climates such as SoCal. Unless one requires a sustained high delivery rate or 'endless' hot water, or lives near the Arctic Circle, skip the tankless and go direct to a HPWH.
  7. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    You have to be careful of what you believe. I too, saw an article to that effect, and remain unconvinced. Utilities use public relations to meet long term goals and do not like to "waste" potential crises. At some point, I believe, stationary power will become nearly free in sunny areas, sans the cost of the infrastructure. We just need a break through.
  8. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Ice storage and Chilled water storage can both store off peak cooling and used in locations with high electrical demand charges and/or large differentials in time of day energy rates.
    Other approaches to dealing with short term peaks at the building level include absorption chillers or use of emergency generators. If you need emergency power or cooling anyway, this is an economical way to deal with peaks and provided the time of operation is short, the energy cost and environmental impact is relatively small.
