California: Hydrogen And Zero-Emission Vehicles Push
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 3, 2014.
  1. bwilson4web
    15,519
    So apparently if you are willing to only drive in California, the fuel cell vehicles will be a great success. Good luck visiting any area beyond 150 miles outside of California.
    49,432
    if you live in california, there are no other states.:p
  3. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Californians get to drive next to a mobile hydrogen refueler? :eek:
  4. hill
    8,168
    $50 million . . . when I think how many PV-powered quick charge stations they could have installed with that money it makes me want to throw my hands up. Zero emission vehicles .... yea, when you don't count the natural gas. What crock.
    hyo silver likes this.
  5. austingreen
    austingreen Senior Member
    13,572
    4,110
    Austin, TX, USA
    Not really that much money compared to how much the state of california just flushes, but ,,,,,,,
    California: Hydrogen And Zero-Emission Vehicles Push | PriusChat
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    What pollution does venting of hydrogen give/cause?
    I'm sure I've read that the highly compressed hydrogen tanks at a hydrogen filling station will slowly vent the fuel into the atmosphere. I appreciate this happens with petrol and that the emissions from a filling station can be significant. But I also read that hydrogen quickly escapes the confines of the high pressure tanks. Will this ever be a problem or will it quickly disappear? Or will they have to ban smoking within half a mile of the place?
  7. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Whatever they put their money on will dictate the type of information regarding environmental impact and cost stories they make up. Far too much of this happening nowadays.
    -Rozi- likes this.
  8. bwilson4web
    15,519
    Hydrogen ignition has one of the widest ranges of ratios, 4-95% by volume. It really is wicked stuff.
  9. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Does it smell? Or will it catch a smoker by surprise?
    With petrol you can smell an increase in the fumes before it gets dangerous. Is hydrogen the same or will you be blissfully unaware of it until it's too late?
  10. Zythryn
    Zythryn Senior Member
    6,252
    4,252
    :eek:
    Well... It is said smoking is bad for your health!:eek::eek::p
    Seriously though, I would be shocked if you could get the needed concentrations just from the normal leakage. Hydrogen is so light, I would expect it disperses very quickly.
  11. Trollbait
    11,539
    I don't think venting is necessary with compressed hydrogen. Some will escape when a car, or refilling truck, disconnects. It is just the nature of handling gases. Unintentional leaks may happen sooner than with natural gas due to hydrogen's physical properties.
    Liquid hydrogen would likely require venting. It will slowly warm up and boil in the tank. When the pressure builds, the gaseous portion gets vented to keep the rest chilled. It is more an issue on a car or tanker truck. The space and mass for insulation isn't as great a limitation for a stationary tank that is likely buried. A refueling station may even have active cooling of the tank.
    It doesn't seem adding an odorant, like to NG and propane, is possible with hydrogen intended for fuel cells. The stations should have sensors to detect levels that get too concentrated. Otherwise, the tiny bit released when the hose is disconnected from a car, quickly gets dispersed. From there 4/5ths of it will get 'eaten' by soil microbes, and the rest eventually goes into out space. Earth is too small to hold onto it.
    Soils control atmospheric hydrogen -- ScienceDaily
    GrumpyCabbie likes this.
  12. austingreen
    13,572
    4,110
    Austin, TX, USA
    In a ventilated area, you know in a wharehouse or street, hydrogen is not classified as a pollutant. It is only dangerous if it is hot enough by the tank, which causes fire or explosion. It will find its way out of most areas and simply rise.
    Venting is done with liquid nitrogen, which is likely needed in the fueling infrastructure. Compressed hydrogen in 10,000 psi does not need venting. It should only vent because of a tank problem or collision.
    wjtracy likes this.
  13. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    No smell, taste or color. The only surprise the smoker would get is his skin suddenly cooking because the flame produced is an almost invisible blue. I would assume almost all refueling stations would have no roofs like Iceland. That way you don't have to worry about accumulation of hydrogen.
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    But wouldn't that cause the tanks to get super hot in places like California or the people fueling their vehicle to get p**s wet through like in the UK?
  15. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    The tanks are usually buried but yeah customers will be exposed to the elements.
  16. austingreen
    13,572
    4,110
    Austin, TX, USA
    I don't think an open roof is a problem with hydrogen, it will find its way up. One reason hydrogen tanks are so expensive is hydrogen is hard to contain. the roof should be high enough so that it is above the head of refuelers until it disipates, but it should only leak from the pump with a malfunnction.
  17. ETC(SS)
    6,552
    Range Anxiety?
    How many charging stations will 68 gigabucks buy?
    Court gives new life to California high-speed rail « CBS Sacramento
    frodoz737 likes this.
  18. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Industry uses H2 all the time all over the globe. Yes it is a flammable gas. But not a pollutant (as per AG) and not toxic.
    Of course, H2 rises quickly in air so we are not exposed to it generally. In some labs H2 is piped all over the place to many buildings as a high pressure gas, as if it were natural gas going homes, but the H2 pipes are nicer looking stainless steel professionally done. Other than that no special precautions although ventilation is generally good. I hate to say by comparison the nat gas pipes to my house look terrible to me.
    There are H2 flammability safety concerns, but seems to be me H2 is managed better, in more modern systems. than say natural gas. If we had to rate substances it would include safety profile vs. how we manage.
    If H2 safety managed poorly by FCV industry then FCV will fail. My guess is H2 safety getting very close attention.
    #18 wjtracy, Aug 4, 2014
  19. Troy Heagy
    Troy Heagy Member
    1,218
    Arizona is desert. Nevada is desert. Oregon is a nice place, but there are ~300 miles of redwoods in the way. Why would anyone leave California? ;) In Norway they have hydrogen stations along highways. Built by the government. If I was a skeptic I might say something like,
    "So apparently if you are willing to only drive in Norway, the fuel cell vehicles will be a great success. Good luck visiting any area beyond 150 miles outside of Norway." ;) :) :D
    Natural gas only takes 1 minute to pump into a Civic GX..... I wonder why hydrogen takes 15 minutes for a Hyundai FCV? Maybe because they are busy cracking the CNG into H2. (They'd save time if they just used the CNG directly.)
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Sweden have a small and growing network of them as do Denmark and Germany. So I guess you now have to change your comment that Norwegians can only drive their hydrogen car 150 miles outside of Germany (Belgium and Holland?) or east of Sweden. There are a handful of them across the UK, though not many and not easily accessible. Probably as easy to find and as well spaced out as the Tesla Superchargers.
