California power outages: What do EV drivers do when this happens?
Discussion in 'Environmental Discussion' started by ice9, Oct 10, 2019.
  1. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Race cars have superchargers, not Teslas. :whistle:
    Sorry, I couldn't resist.
    51,948
    i'll let it go this time...
  3. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    The number I got for our house is 10x of that. :eek: I really would like to built and move to a tiny house totally off-grid, but with running water and sewer and access road for such house, it can get just as expensive.:(
    fuzzy1 and bisco like this.
    51,948
    our daughter wants a tiny house, but you can't find a tiny lot :p
  5. Salamander_King
    11,019
    8,954
    New England
    She can build it on your driveway! ;)
  6. bisco
    51,948
    she could build it on the back forty, but building codes and all that :rolleyes:
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I've posted this already in another thread, but it seems relevant to do it again. SMA grid-tie inverters have a mode called "Secure Power Supply". It provides 1500 watts (2000 watts on newer models) of 120VAC with a non-battery grid-tie inverter. It normally works like any other grid-tie inverter, but you can switch to SPS and have a separate circuit that works with the grid down.
  8. fuzzy1
    10,454
  9. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Ah. So I could charge an EV using my portable Honda EU2200i?
    Problem solved. I just need gasoline! :cool:
  10. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    From what I remember, EV's are "not supposed to" be charged from portable generators, which has to do with the power quality. I think the whole-house generators are good, though.
    #30 Dimitrij, Oct 10, 2019
  11. T1 Terry
    T1 Terry Active Member
    929
    491
    My silver Prius is a plug in hybrid because it has an additional 10kWh battery in where the spare tyre normally goes. We recharge from our motorhome's solar and battery system via the inverter and the 240vac charger. Very inefficient but the power is free and not being used otherwise. It is not a big deal to simply connect solar panels in series till the open circuit voltage (marked on the back of the panel as (OCV) adds up to the upper voltage (fully charged) voltage of your EV battery pack. Then just add a cable and 50 amp Anderson plug with either a mechanical switch or a solenoid contactor into the cable so the Anderson plug is disconnected from the battery when it is not plugged into the solar array.
    There are inverters on the market that aren't real expensive that can handle up to 450vdc on the solar input side and can produce 240vac on the output without needing a battery in between. I posted something about this on the thread about using the traction battery as a back up power supply thread.
    The idea is to run an Anderson plug from the solar input side of the inverter and power selected circuits around the house with the EV battery, then when the sun is shining the solar can both power the house loads and recharge the EV battery. Get an EV with a big enough battery pack, like the new Kona, and have that as the wife's shopping cart/taxi and you have a good battery backed power supply that would have enough to spare to recharge the worker's EV as well.
    These inverters can also be paralleled to double the 5kW output to 10kW or up to 45kW if you really needed it, but you'd need a big battery and solar to keep that powered up.
    T1 Terry
  12. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Most of the areas I saw were rectangular, perhaps 10-20 miles across and 40-120 miles high.
    NOT that big of a deal. If you are required to drive very far you are likely also driving out of the blackout area.
    Map of PG&E power outage zones in Northern California - Curbed SF
  13. bwilson4web
    16,217
    Our 16 kW, Generac system detects the outage and isolates the house from the grid while starting the 2-cylinder, natural gas fueled engine. In about 30 seconds, the generator power routes to the house which includes our 240 VAC, 40 A, 9.6 kW EV charger. Either of our EVs take ~7.2-7.7 kW.
    In April 2011, we had a four-day, grid power outage with no interruption of natural gas for our furnace. Our Prius provided the electricity to run the furnace and keep the house warm.
    Data Daedalus likes this.
  14. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    I was assuming such... ...That's why I was wearing shades.
  15. Dimitrij
    405
    202
    Virginia
    Oh, I thought that was for privacy protection purposes ... :notworthy:
    ice9 likes this.
  16. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    No. That's only if I'm ACTUALLY doing something shady, not when I'm just writing about it. :eek:
    Dimitrij likes this.
  17. Dimitrij
    405
    202
    Virginia
    Whatever, you can talk about this until you are blue in the face ... oh wait ... never mind :barefoot:
  18. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Ditto. You can talk about it and turn blue all you want. Just don't start cracking puns.
  19. Trollbait
    12,543
    Inverters come in three basic types; sine wave, modified sine wave, and square wave. The electricity coming from the power company is sine wave. A generator or inverter that supplies electric in pure sine waves will run anything(assuming the watt draw isn't over the rating) that can plug into an outlet, including charging an EV.
    Cheaper generators may only be modified sine or possibly even square wave(not common anymore), as those are cheaper inverters. Electronics don't run well, if at all, on them, and may even be damaged. Teslas refuse to charge if the car doesn't detect a pure sine wave.
    A portable generator with pure sine wave inverter should be able to charge a BEV.
    Inverter Basics and Selecting the Right Model | Northern Arizona Wind & Sun
  20. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    Yes I was just reading on another board that many Florida residents have relatively large under-ground propane tanks for generators. Apparently underground propane does not have the negative eco-concerns of underground heating oil tanks if leaking. I had not been aware of that approach.
    We do not hear as much these days about using Prius or Prime to generate emergency power, but I assume Prime is good at that?
