California's PG&E Minimum Charge Increasing September '15
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iplug, Sep 15, 2015.
  1. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Well that's significantly different than looking at only the Return On Investment. You CAN afford a PV solar system. Solar City has several different plans that make it economically feasible for everyone.......if you care to check it out. Solar City offers every user a $500 referral fee for every system they sell to a referral. I would be more than happy to pass that $500 directly to you if you buy their system. That is how committed I am to investing in our grandchildren's future.
  2. fuzzy1
    10,713
    While SolarCity does have a bit of operations in my state (Washington), one of their reps has been quoted as saying their leasing program is not economically viable here.
    I've also heard several statements that leased systems have been a liability when selling a home. Some potential buyers are unwilling to take on the lease obligations, and want the seller to buy out the lease first. Does anyone here know of any specifics either way?
    Obligatory disclosure: I am a retiree with a wholly owned DIY net-zero system.
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I have a nice solar system saving me $1000/year in electricity costs. Any larger investment for long term good deeds is not appropriate for me.
    #23 CaliforniaBear, Sep 17, 2015
  4. el Crucero
    1,628
    699
    Inland Empire
    That doesn't make a lot of sense. What buyer wouldn't want to take on a $50/mo lease in order to save themselves $100/mo in electricity cost? If a lease payment is more than the net savings in electricity, then a PV system is not appropriate for you.
    that works too
    Oh, your postings gave me the impression you did NOT have a PV system, my fault. Good, that works too. But since you say your system is undersized for your needs because you still spend $200 to $300 per year (about $20/mo) on electricity, you could spend $2000 for two more panels, reduce your electric costs to $0, and increase your ROI to around 9%!
  5. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Regarding the bolded item (emphasis mine) - this is not correct and my whole point. As mentioned, if you look at your rate plan (E-1, E-6, etc), its a several page document. Tiered electricity prices are accounted for separately from your connectivity and maintenance charges. If that is not actually what PG&E is doing, that's an ethical and possibly legal problem.
    What you are charged for your electricity use should have no bearing on my or anyone elses connectivity or maintenance charges. Why should the solar panel users with net zero or greater systems subsidize others?
    That doesn't make sense. Both parties agreed to the contract signed. There is no time machine. The point was that the deal changed. They basically said, forget the accounting we told you and you agreed to, we're just going to take more from a few select customers because we can.
    Good to see the system continues to work well for you. Fairness, good business practices/ethics, and public goods are also important to many.
    Tracksyde and el Crucero like this.
  6. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Your neighbors only get charged that 33 cents a kWh during peak hours if they have exceeded their Tier 1, 2, and 3 allowances towards the end of the month. In fact, Tier 4 has now dropped to 32 cents a kWh as of September 1st. PG&E is also in the middle of revising their E1 rate schedule and eventually will only have two rate tiers for E1 instead of the current 4 tiers. The most recent proposal from PG&E was that Tier 1 eventually will be 19.5 cents per kWh and Tier 2 23.5 cents per kWh sometime in 2017.
    It should be noted that
    1) The current muli-tier rate structure was in response to the Energy crisis of 2001. Prior to that we didn't have a multi-tier system.
    2) The reforming of the current residential rate structure is mandated by AB 237 which was passed in 2013. So it's not like PG&E
    came up with this on their own. SCE and SDG&E are also implementing this.
    As to the $60 a year increase, yes, it sucks. But it is relatively minor, and we as solar users do need to help pay for the upkeep of the transmission infrastructure, which includes all the neighborhood level stuff. The past couple of years we've had to walk away from a $50 to $100 monetary credit because of a) the minimum connection charge, and b) the excess energy credits we accumulated in the last two months of our true-up period. But I've gone from paying PG&E an average of 3 grand a year to paying them less than a $100 per year for electricity. Our solar lease is only $105 a month. So that means I'm saving $1700 or so a year. I can afford to pay them an extra $5 a month to not have to pay them $250 a month...
    CaliforniaBear and el Crucero like this.
  7. el Crucero
    1,628
    699
    Inland Empire
    A very fair analysis, thank you. I just look forward to the day when I can go completely off grid.
  8. devprius
    devprius /dev/geek
    979
    291
    I should correct myself, prior to 2001, there was a sort of multi-tier system. You had a base rate which was 11.5 cents a kWh, and when you exceeded some amount at that tier, it then was 13.3 cents a kWh. There were no other tiers or surcharges until May 2001, when the 5-tier system came into existence, at least within PG&E's territory.
    #28 devprius, Sep 17, 2015
  9. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    That's not the case here as this happens long before the end of the month. In the SF bay area this may be true where housing sq. ft is significantly smaller and temperatures are significantly more mild than here.
    For example, all of my non-solar neighbors monthly bills are into the upper tiers for most of the month. If we were to average their monthly bills, they would be well into the $0.2x/kWh range. I think the $0.33/kWh figure is fair as that is what PG&E would charge me during those hours of over-generation and they are the most valuable to PG&E and the grid. Understand other arguments as well.
    Agree. But while solar over-gerneration may be a problem some day, it has not been recently nor currently. In fact, home solar has kept costs for neighborhood transmission down, at least where I live. With grid generation microsources like solar produced locally, that saves on building new transmission lines, transformers, etc. Sure, that may not be the case everywhere and in the future this may change.
    I'm ok with paying a few more dollars monthly if that is indeed my fair share. I just don't believe it is and think connectivity and transmission fees should be the same for all local consumers regardless of their solar status. Being plugged into the grid is at least as important for non-solar users as it for most solar users.
    #29 iplug, Sep 18, 2015
    Redpoint5 likes this.
  10. devprius
    devprius /dev/geek
    979
    291
    Despite living on the coast with it's milder temps and no A/C to run, we hit the top Tier every month before we put Solar on the roof. Average family of four. Our average charge per kWh was 28 cents or more, sometimes hitting 34 cents. Inland customers, especially those in your area, have a baseline that is nearly twice that of us on the coast (13.8 kWh per day versus 7 kWh per day). And having lived in a sunny climate where A/C was a necessity, I don't begrudge you that extra baseline amount.
    PG&E still has to maintain the local grid, and we do affect the local grid with our generation and consumption. PG&E, SCE and SDG&E all wanted to add a fixed charge to everyone's bill, starting at $5 and increasing to $10 in 2017. This was in addition to charges for actual usage. Thankfully the PUC told them no and instead instituted the minimum bill charge.
    But remember, the $10 a month they are now charging us is applied as a credit at the end of the true-up period, just as the $5 fee was earlier. So if at the end of the true-up period we owe PG&E $120 for all the electricity we consumed, our true-up bill ends up being zero. And depending upon how wet the winter is this year, it's quite possible that winter production will be very very very low and we could end up owing money to PG&E. Our first true-up period had us owing PG&E about $60 when all was said and done. Last year we owed $5. This year we walked away from a $59 NEM credit. Sucks to be us.
  11. dipper
    dipper Senior Member
    1,242
    252
    One could always sell their gasser, buy an EV to get their $120 back. And not pay for gas. Win/Win, I say. :D
    Those Nissan Leafs are so cheap for a 3 to 4 years old car.
    devprius likes this.
  12. devprius
    devprius /dev/geek
    979
    291
    Heh! Nice idea...
    We're hoping that Tesla makes good on their promise of a 2017 delivery date for the Model 3, and actually hits the target price. The PiP will then become my wife's daily driver...
    el Crucero likes this.
  13. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Yes, but residential solar generally has a more positive effect than negative on the local grid in these terms, so why stick it to the solar guys? That's an argument for residential solar to pay fewer of these fees, not more.
    If that's the case, it's one of the rarer cases we should get behind the private utilities. That is far more fair. Non-solar users need the grid at least as much. Please explain why you feel otherwise.
    Many with solar are also working on minimizing their carbon footprint. So while such a cost optimization game is fun and makes sense to many, the environmental angle has a lot of weighting for others too. Therefore net zero or negative is also a winning objective.
