Caliper will not fit over new pads and rotors? Please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sidewayzgt, Apr 7, 2017.
  1. Sidewayzgt
    Sidewayzgt Junior Member
    Los Angeles
    I just bought new pads and rotors for my 2011 Prius gen 3. I bought Duralast 44662 Rotors and Duralast DG1184 brake pads. Everything fits on perfect until I tried to reinstall my caliper which just will not fit over the shims. I have compressed the caliper as much as it can go but it does not help. Do I grind down the shim? I'm stuck. Thanks
  2. ChapmanF
    15,478
    Will they refund your money so you can buy Toyota parts?
    -Chap
  3. Sidewayzgt
    Los Angeles
    I'm not asking about Toyota parts, I'm asking about these (Duralast) parts. I just want to make what I have fit. The Autozone website says that I have the correct brakes (Rotors and pads).
  4. Sidewayzgt
    Los Angeles
    I'm taking them back tomorrow and getting my money back. They should fit with no issues.
  5. Mendel Leisk
    38,653
    ^ Good plan. I too would just go with Toyota.
    FYI, some (new) thickness specs:
    Front rotor: 25.0 (mm, typ)
    Front pad: 10.0 (without backing plate, so not that conclusive)
    Rear rotor: 9.0
    Rear pad: 9.5
  6. jas8908
    jas8908 Member
    42
    38
    dallas
    Did you remove the brake fluid cover when compressing the pads?
  7. Mendel Leisk
    38,653
    ^ Doesn't do anything.
  8. Sidewayzgt
    Los Angeles
    I solved it by returning the Duralast
  9. Mendel Leisk
    38,653
    Toyota parts fit?
  10. Tande
    Tande Active Member
    502
    302
    Mich.
    Are we talking front or rear??.......if rear, I suggest that the piston is not FULLY retracted (screwed in).......FWIW, I have successfully used "Duralast" pads & rotors on the rear of my Gen 3 :confused:........
