Calling a spade a spade
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, Sep 1, 2020.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The benefit of liquid-cooling really only comes into play when DC fast-charging beyond tier-1 speeds (50 kW).
  2. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I heard some EVs (Tesla?) actually start the cooling cycle while parked in hot weather?
  3. john1701a
    12,840
    5,312
    58
    Yes, but that feature works with any type of non-passive cooling. In the case of RAV4 Prime, that would be available using A/C air pushed directly through the battery-pack.
  4. RealCCN
    RealCCN Junior Member
    IL
    You're very welcome! Toyota has gotten significantly better on their language in their prints. Repair manuals and internal documents however is still business as usual. I guess google translate from Japanese to English only goes so far.
    Agreed. Most people would think liquid cooling is coolant cooling like the inverter. Pretty interesting how the battery essentially counts on the refrigerant and with the high price of the R1234yf I wonder if at some point somebody is gonna decide that they don't need A\C and find out the hard way that they do.
    I personally dislike the new refrigerant at $100 a pound makes servicing very difficult and costly. Car comes in with a leak that we can't immediately detect and the sniffer really doesn't work as well on very small leaks and We'd be charging the customer $300-400 for a recharge and 1 year later we're back to square one. We're already dealing with this on patient zero the 2016 Tacoma.
    Trollbait likes this.
  5. Trollbait
    12,830
    For plug ins with actual liquid cooling, the battery pack is cooled with the same loop as used for the inverter.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    Is that because DC fast charging creates more heat than Level 1 or 2?
  7. Mendel Leisk
    42,349
    Some where in Owners Manual it says change oil yearly, regardless of Maintenance Minder percent remaining.
  8. Trollbait
    12,830
    Yes, but there are benefits to liquid cooling for below those charging speeds, and water is simply a better cooling medium that air no matter how hot something gets. The benefit besides direct cooling is that it allows a smaller, cheaper pack.
    Because air isn't efficient at removing heat, more of it needs to flow through and around the battery. This means larger channels that lead to a bulkier pack for the weight. With water being a better coolant, less expensive chemistries can be used, leading to a cheaper pack.
  9. Marine Ray
    1,139
    949
    Sparks, NV
    Thanks for the explanation. Based on space available I've seen from Prof Kelley's WSU videos, I'd say the PP could gain maybe 5-10% more kWh if liquid instead of air cooled. Your thoughts?
  10. Trollbait
    12,830
    Haven't watched the videos, but liquid cooling will make it easier to package the battery in a way to lose less space. Which is likely one of the reasons the Rav4p has refrigerent cooling.
    Marine Ray likes this.
  11. El Dobro
    El Dobro A Member
    7,106
    3,282
    Regarding the fuel aging, doesn't the Prime have a pressurized fuel tank to extend the life of the fuel, like the PiP and Volt?
  12. Trollbait
    12,830
    Yes.
    I think all cars do now. That's why a loose gas cap throws a code.
  13. Prodigyplace
    12,715
    11,848
    Central Virginia
    Actually on the Gen 4 you only have 30 minutes to refuel before a flap seals the tank from the filler neck. If the nozzle accidentally hits the latch, you end up with fuel on the pavement. I have not tested but I doubt a loose cap throws a code on Gen 4.
  14. ChapmanF
    19,025
    Any year of Prius will give you a code if the filler cap is loose, but that's (in the older models anyway) because of self-tests of the system meant to keep vapors from escaping, not any fancier strategy to keep the fuel fresh.
  15. El Dobro
    El Dobro A Member
    7,106
    3,282
    In the PiP and the Volt, you had to wait for the car to give an ok to refuel after pressing the button.
  16. Bill Norton
    Bill Norton Senior Member
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    That's because those two PHEV's and the Prime have a 'fancy' pressure based evaporative emissions control system, not vacuum based like most other cars.
    Supposedly to keep the fuel fresh for longer periods.
  17. El Dobro
    El Dobro A Member
    7,106
    3,282
    Yep.
  18. Bill Norton
    2,246
    754
    MONW, Ks.
    2019 Prius
    L Eco
    "Penguin- the other white meat." in your signature.
    Salmon, the other pink meat!!:)
  19. ChapmanF
    19,025
    I was responding specifically to post 132, which suggested for "all cars" that a pressurized system is why a loose cap throws a code. It'll throw a code even in the older models, even though a pressurized system isn't why.
    That was the point of the "in the older models anyway" in my post that you replaced with ....
  20. Prodigyplace
    12,715
    11,848
    Central Virginia
    Gen 4 as well.
