Calling all Aussies and Kiwis !!
Discussion in 'International Owners' started by norman, Mar 27, 2004.
  1. kentricho
    kentricho Junior Member
    59
    Melbourne, Australia
    Thanks Sleeka... Nah I'm prepared to wait for my black Prius, thanks for letting me know though :)
    What sheepskin covers did you get? I also want to get some nice seat covers to protect the leather.
    CHeers mate,
    Kent
  2. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    <div class='quotetop'>QUOTE(kentricho @ Jul 24 2006, 08:26 PM) [snapback]291345[/snapback]</div>
    Hi Kent,
    The covers were custom made by a sheepskin cover specialist here in Brisbane[attachmentid=4236]. My wife does embroidery, so we have logo badges set into the backrests. You should be able to find a sheepskin specialist in cold old Melbourne, surely? I have attached a photo of them for you.
    Regards,
    John.
  3. Orf
    Orf New Member
    414
    Devonport, Tasmania
    Looks beautiful. I see you don't have side air bags.
    Well done Mrs sleeka.
  4. kentricho
    59
    Wow, they look absolutely fantastic Sleeka! I tried searching for people in Melbourne, the only ones I could find are generic ones, not custom made like yours.
    Did you go through http://www.jumbucksheepskins.com/ by chance?
  5. Aussie56
    Aussie56 New Member
    34
    Nice Sheepskin covers, Sleeka. I went with sheepskins too, but not custom. The velour is just a bit fragile for everyday use. My centre console is starting to get a bit untidy where I lean on it, so I might go for sheepskin there too. I like the logos too.
    Where did you get them made in Brisbane? I'm coming down there in a couple of weeks to get the steering recall done among other things.
  6. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(Aussie56 @ Jul 26 2006, 01:36 PM) [snapback]292387[/snapback]</div>
    Thanks for the appreciation, guys. Yes, we like them, too.
    No, they were not done by Jumbuck, Kent, come up for a short holiday when you get your car and get a proper set fitted...and no, we don't have side airbags, Orf...ours is a base model. They can be done for side airbag cars, though.
    Aussie, send me your email address on my Personal Mail (PM). I'll help you get the console cover organised in advance ready to be fitted while you are down here if you like. We can also organise the logos for you in your choice of colour if required.
    Our car goes in for the steering recall next week. You have to go in for an inspection first, then they determine (a) if you need rectification work done; then book it in for the rectification if required.
    Regards,
    Sleeka.
  7. Aussie56
    Aussie56 New Member
    34
    Thanks Sleeeka,
    I sent you a PM.
  8. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(sleeka @ Jul 26 2006, 10:51 AM) [snapback]292572[/snapback]</div>
    My sheepskin covers were left over from my Commodore. They have the part where the side airbags are cut out. Makes them look a bit like a waistcoat. I had to modify the straps where they go down between the back and the seat so that they did not interfere with the seat wiring.
    Sheepskin covers not only give that luxurious look they also feel great to sit on.
  9. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(Orf @ Jul 29 2006, 02:28 PM) [snapback]294174[/snapback]</div>
    Orf.
    Yes, genuine sheepskins are great in both hot and cold weather because of their luxurious pile, and the fact that they "breathe".
    With the side seat airbags, the current way of doing the covers to allow the airbags to deploy is to weaken the skin itself by cutting staggered slits in it similar to a pattern (say) on an aluminium screen door. These cuts are invisible through the pile, the covers still hold their shape, but if/when the airbag goes off, it simply breaks the weakened area of the skin and deploys normally.
    Regards,
    Sleeka.
  10. Orf
    Orf New Member
    414
    Devonport, Tasmania
  11. kentricho
    59
    Hi Orf,
    Sorry this post isn't related to your question above, but I read in an earlier post on this topic that you had found a spreadsheet where you record all of your fuel data etc.
    Are you able to get me a copy by chance?
    Thanks,
    Kent
  12. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(Orf @ Aug 2 2006, 02:42 PM) [snapback]296093[/snapback]</div>
    Hi Orf.
    No, I didn't get that one before, although this one looks fairly comprehensive. The seller only ships within the US though.
  13. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(kentricho @ Aug 2 2006, 12:43 AM) [snapback]296116[/snapback]</div>
    I ended up with about 5 different spreadsheets from around the world. The only one that I thought was worth persisting with is one from Singapore. I have modified it because the Singa Prius has a different size tank.
    However, I found that there was a huge difference between the Last Tank readouts and the Lifetime Calculations. For example, my last tank readout was 4.58 L/100km whereas my lifetime readout was 5.34.
    After scratching my head and becoming completely confused as to how to calculate fuel consumption figures I scrapped the Singa method and adopted my own - it is now independent of tank size. This has given me figures of Last Tank 5.449 and Lifetime of 5.577L/100km. These figures may seem high but most of my motoring is over short distances, stop/start over 5 km.
    Another thing, my MFD fuel consumption got itself accidently reset while I was cleaning the MFD with the power on. Seeing how it was buggered up I then went on to use this feature to calculate fuel consumption over several separate trips. It is only since my last fill-up that I have left it alone to check it against my next calculated figures.
    I also made the date of inputting entries in the spreadsheet automatic but it has a bug and resets to todays date every time the spreadsheet is opened. I have a fix for that but have not put in the script.
    Also, I have not completed the definition page alterations to match my changes, so they could be misleading.
    Once I have had time to fix these discrepencies, sure you can have a copy.
    My tardiness in not completing the spreadsheet has been caused by the problems I have had in setting up my VOIP telephone system. I think I now have that working and am enjoying making all my phone calls for 1¢/minute.
    <div class='quotetop'>QUOTE(sleeka @ Aug 2 2006, 11:28 AM) [snapback]296334[/snapback]</div>
    Looks like another good idea shot to hell. I wonder if we can arrange a group buy of the service and parts manual and get someone State-side to do our shopping for us?
  14. Orf
    Orf New Member
    414
    Devonport, Tasmania
    Just went to the Ebay site and found this:
    **NEW** Buyer’s can now instantly Download and use this Prius Tech CD after purchase.
    NO Hassle
    NO Wait time.
    NO Shipping Fees
    After purchasing buyers will receive an email with download instructions.
    I wonder if it is possible to burn a CD from the download?
  15. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(Orf @ Aug 4 2006, 01:45 PM) [snapback]297488[/snapback]</div>
    Orf.
    Why don't one of us but it, try to burn a CD, and then share the cost of burning duplicates and postage?
    I'd be in it.
    Regards,
    John.
  16. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(sleeka @ Aug 7 2006, 01:15 AM) [snapback]298912[/snapback]</div>
    Hmmm. Let me think about that. On the surface seems like a good idea but I am not sure of the supplier.
    Been working on the fuel spreadsheet and have nearly got it finished. Just need to tidy up the graphs.
    Just had another look at the eBay site:
    http://cgi.ebay.com/ebaymotors/2003-2006-T...012576574QQrdZ1
    Have you seen the part of the manual on display?
  17. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(Orf @ Aug 7 2006, 05:34 PM) [snapback]298931[/snapback]</div>
    Hi Orf,
    Yes, it looks like the factory manual page layout.
    I have inquired with the seller about buying the download copy, and the size of the file. I'll let you know the answer.
    John.
  18. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(sleeka @ Aug 7 2006, 03:00 AM) [snapback]298938[/snapback]</div>
    Thanks, John.
    It will be interesting to see how complete the manual is.
  19. sleeka
    sleeka Member
    249
    <div class='quotetop'>QUOTE(kentricho @ Jul 26 2006, 01:22 PM) [snapback]292377[/snapback]</div>
    Hi Kent,
    Try http://www.autofleece.com.au They will do mail orders from Brisbane. Tell Stan you were talking to John from the Toyota Car Club, and are interested in the embedded logos. We'll get them done for you if you want them. Make sure you tell him that the car has side airbags, though.
    Regards,
    Sleeka.
  20. kentricho
    59
    Hey John,
    Thanks heaps for that. I'm still waiting on my car to come, but I'll definitely consider the car seats, they really do look unreal.
    Are your ones the 'alpha' style?
    Cheers,
    Kent
