Cam and crank signal in techstream.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Nov 15, 2024.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    I can't seem to find it.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    What are you trying to accomplish?
    The only crank position "data" on (any) scantool is RPM.
    Some cars have data showing whether or not the camshaft position is where the ECM expects it to be.
    Toyota doesn't have that in normal engine data. It sort of has that in the bidirectional VVT tests.
  3. Prius92
    595
    122
    Iowa
    I keep getting P0016 "cam and crank timing correlation".
    I took the valve cover off, set Cyl 1 and verified both cam shafts and crank were in alignment.
    All of the timing components are brand new.
    I checked the cam and crank sensors for proper resistance.
    I just had the VVT-I solenoid warrantied under autozone and I'm hoping that possibly the solenoid was bad, because I can't figure out what else would cause this.
    Only other thing I can think of is possibly a bad 12v battery.
    The workup for it in the FSM says either the timing is jumped or the ECM is bad. I've never had an ECM just "go bad".
  4. Prius92
    595
    122
    Iowa
    The new solenoid didn't fix it.
    Could the ECM possibly be bad?
  5. ChapmanF
    18,993
    Someone (@mr_guy_mann maybe?) has posted a thread here some time ago that showed use of a two-channel oscilloscope to observe the crank/cam correlation, if that's of interest.
  6. Prius92
    595
    122
    Iowa
    Well the factory service manual only states 2 things for P0016:
    1. Engine out of time (physically)
    2. Replace ECM.
    I found a used ECM for my year for $24 shipped.
    I recall reading a thread where someone (might of been Mr Guy Man as well) that P0016 was incorrectly set when it should of been P0011 or P0012.
    If that's the case, the FSM also says this:
    DTC P0011 or P0012 is output when a foreign object in
    engine oil is caught in some part of the system.
    Love how it says "some part".
    Also:
    These codes will stay registered even if the system returns to normal after a short time.
    I'm still suspecting possibly the timing gear assembly, the big clutch pack looking thing mounted to the intake camshaft.
  7. highmilesgarage
    highmilesgarage Active Member
    494
    184
    Kansas City
    in some cases it's a stretched chain (I have that issue in mine) and I bought a cloyes kit. What brand did you use? I think it matters because a slight difference in the chain triggers p0016.
    p0011 and p0012 are cause by VCT solenoids (dirty or bad) usually gets fixed by cleaning or replacing.
  8. Prius92
    595
    122
    Iowa
    00-19 Timing Chain Kit For Scion Toyota Echo 1.5L L4 DOHC 16v DNJ TK949 | eBay
  9. highmilesgarage
    494
    184
    Kansas City
    never heard of that aftermarket brand, when it comes to timing components and critical sensors stick with a known brand
  10. mr_guy_mann
    4,111
    2,011
    NJ-USA
    The engineers who write the service manual make assumptions. Sometimes those assumptions are wrong. Sometimes failures occur in ways that were not anticipated, that don't account for real-world wear & tear.
    Short form is P0016 means that the cam position signal doesn't occur when the ECM expects it (with relation to the crankshaft signal). In theory having a correlation fault with different conditions (VVT commands?) should instead set P0011 or P0012, but that doesn't always happen.
    Due to the lack of VVT data in the scantool, the only way I know to "see what the ECM sees" is to use a 2 channel oscilloscope on the cam and crank sensors.
    Then I compare to my known-good reference patterns. Is the camshaft advanced (early) or retarded (late). By how much. Does the relation change at all without VVT. What happens with VVT.
    Not many DIYers have access to or experience with any scope, let alone a 2 channel.
    "Lining up the dots" during chain installation attempts to insure that there are no gross assembly errors. There could be a problem with the VVT actuator - sprocket assembly (the cam to sprocket relation could be incorrect). Or a twisted camshaft. Or "damaged" sensor trigger. Or the chain jumped before the tensioner was released. Or the "wrong" alignment marks were used. Or some other weird fault.
    A few scantools such as Techstream or ThinkDiag have bidirectional tests. I do not know what the VVT test data would show (or if it would run) on a car with a correlation fault. Might give more info, or not.
    It could be that the chainset is the problem. Without data from testing, it's all guess-work.
  11. highmilesgarage
    494
    184
    Kansas City
    if you have the original chain it will provide insight on how much is the stretch (if there is) Normally a stretched chain will always have the timing marks in-line (not even a tooth off) When I compared mine the difference between old and new is very small and I can't believe that will cause p0016. I only replaced the tensioner and chain, the gears weren't even touched.
