Cam shaft error
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Smardaz, May 2, 2017.
  1. Smardaz
    Smardaz Junior Member
    26
    Tacoma, Washington
    2024 Prius Prime
    XSE
    So every once in while I get a check engine light and when I connect my reader it comes up as a cam shaft position error. It does not stick around long. Anyone else get this? Should I be concerned?
  2. TWOPrius
    TWOPrius Junior Member
    51
    Tampa
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Well, last time I saw one of those, I checked under the bonnet, and the cam-shaft was exactly where I though it was supposed to be, so I have to admit that I ignored it! ...but seriously (folks) I wouldn't worry too much about it if it's only a "one-off", but you might want to look out for it just in case it's the start of something bad! BTW Welcome to PriusChat!!
  4. Patrick Wong
    18,210
    6,513
    What fault code is logged?
    This sounds like an intermittent wiring harness connection to the camshaft position sensor.
    johnjohnchu likes this.
  5. johnjohnchu
    johnjohnchu Active Member
    212
    105
    I do get similar error code approximately a couple times a year. I think it was P0011. Every time, I just cleared the code and moved on. Also, changed the timing control valve filter, but it did not resolve the issue. Plan to look into the possibility of loose electric connection as suggested by Pat. It is a low priority issue for me since it rarely happens.
  6. Smardaz
    26
    Tacoma, Washington
    2024 Prius Prime
    XSE
    Same code as Johnjohnchu, i wasn't too worried but twice today I've gotten red exclamations and "problem" on the screen while going downhill, i do not know what the hell is going on
  7. Patrick Wong
    18,210
    6,513
    When was the last time you checked your engine oil level on the dipstick?
    johnjohnchu, valde3 and Mendel Leisk like this.
