Camber Adjustments (Wheel Alignment)
Discussion in 'Gen 3 Prius Technical Discussion' started by taliscope, May 2, 2023.
  1. taliscope
    taliscope New Member
    Summerville
    Hello,
    I just had new tires and an alignment done, and had a question about Camber measurements and whether an adjustment is needed. I've been reading through the different threads on the forums, and it seems there are some things I could do about it (with corrective bolts), so before trying I thought I'd ask for advice.
    My 2015 Prius had a front right collision with the previous owner, so Camber & Toe have been off. Toe has been fixed.
    Current measurements for front left camber is -.20 degrees, and for front right it's -1.40 degrees.
    Is the difference between Camber on the two wheels a cause for concern?
    I attached the before and after alignment measurements as images, so any other alignment advice is appreciated!
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    You look online and you determine the size bolts that hold your strut on right now 10 mm I think is the general You order Camber adjusting bolts. Sometimes called crash bolts the big manufacturer's specialty products corporation if you Google them you can even look it up probably by your car model and get the right bolt usually what I've had to do in the past is either take one of my bolts off or look them up on the Toyota parts and then specialty products will convert that part to their bolt which will come with the bolt with an eccentric in the middle of it and a nut and maybe a washer You only need one per side The person doing the alignment depending upon how much adjustment you need will determine whether to put it in the top or the bottom bolt hole If he's already going to be adjusting camber he's going to take the nuts loose so he might as well take one bolt out bang in the crash bolt make the adjustment lock everything down without too much of a labor hub bub.
  3. taliscope
    Summerville
    Thank you! Would you be able to tell me if the current Camber measurements are a cause for concern? Will my tires have uneven wear, or am I ok leaving as is?
  4. Tombukt2
    13,864
    2,519
    Durham NC
    In my world my belief is you have two degrees almost of negative camera on one side of the car and about a half a degree on the other I would want to try at least in the front end to get that right near just under 1° of negative camber for the front get the toe straightened out which should be just an adjustment and the same with the camber but the camber bolts one on each side and tried it adjust the camber to just about 1° - a little bit less whatever I'm not even sure what it's called for I know in my personal cars I run close to a degree of negative camber and that gives me decent handling very even tire wear etc having 1.5° - camber on one side and what you have on the other and the toe being out should at least be brought into spec. For tire wear sake and all
    taliscope likes this.
  5. Mendel Leisk
    42,352
    Alignment specs fwiw:
    zeng and taliscope like this.
  6. ChapmanF
    19,027
    By lucky coincidence, camber adjustment got discussed only recently over here. Somebody posted an excerpt from a 2010 manual. [Edit: yup, it was Mendel, who I see has struck again here while I was writing this.] Here are the specs:
    Looking at your tire size, and assuming you don't have the Rough Road Package, it looks like your left front camber was spot-on before they fussed with it (unless 2015 specs are changed from 2010).
    The right front camber is clearly out of spec, both in absolute terms (it's not within -0.22° ± 0.75°) and relative ones (it's not within ±0.75° of the left front). Ideally, you'd want to shift that 1.18° in the + direction from where they got it. That's quite a change.
    Toyota sells those bolts in four flavors: the original factory ones (no pips on the head), and three progressively skinnier ones with one, two, or three pips.
    So you start by looking at which two are already there, and match those across the top in Table 1. Looking at how much of a change you want to make, 1.18°, you see the second-last row in the table is for 1.00° to 1.25°. If you are starting with both original no-pip bolts, the table says swap to bolt pattern E (a two-pip on top and a three-pip on the bottom). If you've already got a no-pip and a one-pip, you can swap to pattern F (three-pip bolts top and bottom). If you've got any other combination of bolts there to start with, you're out of luck; there's not enough adjustment left to get the camber in spec (but you could still get it closer by reading up the table until you come to a row with a bolt pattern shown).
    You can see the part numbers for the different bolts are also given.
    Once the bolts are swapped, the skinnier bolts mean there is more slop in attaching the knuckle to the strut. The key is to finish off by leaning the knuckle in the proper direction (+ in your case) before tightening those bolts.
    Because the table above came from a 2010 repair manual, it may be worth checking that nothing changed in the 2015.
    Also, if some of the bolts there have already been replaced by aftermarket ones that might not be sized or marked the same way as the Toyota ones, it could be trickier to pick the next combination needed.
    For future readers: there's also a Table 2 (see the full thing Mendel attached) for when you need to adjust in the other direction.
  7. taliscope
    Summerville
    Thank you! Will do my best to adjust.
  8. taliscope
    Summerville
    Thanks for that!
    So I believe the following are the part numbers I need:
    • 90105-17017
    • 90105-17018
    Would you have any guidance on where to purchase from? I found the following links for Toyota, but wasn't confident if I found the exact parts.
    Link to 17017: Toyota Parts
    Link to 17018: Toyota Parts
    Can you confirm that I found the right links? Also do I buy a Type B and Type C from both of these links, or just one set of Type B and Type C from one or the one of these links?
  9. Tombukt2
    13,864
    2,519
    Durham NC
    An alignment place with the proper bolts and what have you should be able to get you in pretty good shape pretty quickly some places carry the specialty products line of front end bolts shims and nuts specialty products could tell you who in your area is approved alignment shop that uses their products or you can take it to the Toyota dealer and they have their own Toyota bolts that are very similar I am sure they will cost more money but he got to do what you got to do.
  10. taliscope
    Summerville
    Ok, noted. I will try to find the parts and go to a local shop to work it out. Thanks again!
  11. ChapmanF
    19,027
    Any Toyota dealer should have them or be able to get them.
    There are just four flavors of bolt (no pips, -17019, one pip -17016, two pips -17017, or three pips -17018).
    The reason there are seven corrective recipes, A through G, is each recipe requires two bolts. Recipes F and G both involve two bolts of the same flavor, and the other five recipes all have one bolt to go in the top and a different one to go in the bottom.
    Can you show your work for how you came up with B or C, when I tried to show my work in post #6 and came out at least E? Are we talking about the same car?
  12. Tombukt2
    13,864
    2,519
    Durham NC
    I didn't have to do any of the pipping that I remember and if you put the eccentric bolt in the top or the bottom and a regular bolt and the other hole it changes the camber a little more. I use the specialty products brand bolts nuts and washers because they've been doing this a long time I'm not sure that the bolts from the Toyota dealer are the eccentric type except for the last two that talk about moving them from the top to the bottom or vice versa this is discussed on specialty products website too realize they've been making these things for a long time for the alignment industry that's why I went with their bolts I didn't even know Toyota offered crash bolts or didn't initially and so I bought them from specialty products and I would imagine the Toyota dealer wouldn't have these in stock I know they'll get them but my alignment place carries the specialty products and generally will have what can work in my Toyota's on the shelf because it's pretty popular We can also buy the one with the most eccentric or the biggest bump on the eccentric It gives you the most move and said it where you need it and forget it You don't have to worry about the pips or getting the bolts real close to the original size and just a little shaved off so you can get just what you need. I go for the ones with the eccentric and my alignment guy can get me plus 3° and -3° or whatever the movement is close to that It's at least 2° when I was doing this a lot we were auto-crossing cars and so we were looking for about 1.3 to 1.4 negative camber in the front end this was the old days
  13. taliscope
    Summerville
    Ok noted!
    Trying to move 1 degree towards postive. Which would be E like you said.
    From "Selected Bolt Combination" table I went to the "E" Column. Under E, top bolt says 17017 bottom says 17018.
    Did I do the wrong measurements? Or maybe I'm reading the table wrong. Can you advise?
  14. Tombukt2
    13,864
    2,519
    Durham NC
    The camber changes more whether you have the adjust bolt with the offset on it in the top of the bottom hole I don't remember which way you can read about this on pretty much any alignment website we'll talk about it on my Auto X cars Toyotas I've had them in both positions I can't remember what ended up being the de facto standard if there is one so usually the regular bolt will be in the bottom of the top and the specialty products or the Toyota offset bolt or whatever Toyota's using just a thinner bolt so you can move I don't know I've never seen the Toyota part I'm guessing they may just be a skinnier bolt the shank so that you can move. Good luck by the way if you want to look online if you look at specialty products corporation I believe it is they will have extensive write-ups and how to's and what have you I do believe
  15. ChapmanF
    19,027
    Yes, that sounds more like it. When I went through it, it looked like you'd want 1.18° toward positive, which would fall into the 1° to 1.25° row, and that would be pattern E if the bolts you have in there now are both the no-pip original bolts.
    If the ones in there now are a no-pip on top and a one-pip on the bottom, you would need to go to pattern F. And if the ones in there now are any more extreme combination than that, there won't be a combination available from Toyota to get you in spec. (And if the ones in there now aren't Toyota bolts, it's hard to say anything.)
    So yes, if the ones there now are both no-pip Toyota bolts, then you want to change them to a -17017 in the top and -17018 in the bottom.
    Something in your post #8 mentioned B or C, and that's what I was asking about before. Looks like we agree it's more like E or F.
  16. taliscope
    Summerville
    Whew, ok! Thanks so much. Will go with those two.
  17. taliscope
    Summerville
    Thank you! I found the right bolts now.
  18. taliscope
    Summerville
    Ok so here’s the current bolts that are on the vehicle. Initially I had thought they were the originals. But they seem to have some sort of markings.
    I checked the opposite side of the car and they have the same markings and same quantity.
    Would anyone be willing to check their vehicle to confirm whether these are the original bolts? (With 2 dashes or “II” in the center)
  19. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    -double post-
  20. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Instead of securing original Toyota camber bolts suggested above, which carries some risk/probability of mismatch, I would think an aftermarket SPC 81290 camber bolts provides an ideal solution here.
    Specialty Products Company | SPC Alignment | The Automotive Alignment Leaders
    Curious to check if your Prius pulls/drifts to the left on tracking straight ahead driving?
    Steering wheel being off-centre, likely to the right on tracking?
