Camera modification to show line and distance?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Francos, Mar 25, 2013.
  1. Francos
    Francos Member
    118
    I get used to my Odyssey camera, which has lines to show the distance to objects behind. My basic PIP does not have the feature. I am thinking to draw some lines on a screen protector film, and attach it to the camera. It may be a great idea.
  2. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    One thing I havent been able to confirm, but suspect, is that the camera is what produces the lines on the screen. For all the Prius owners who dont have a rear-view camera but install one, it sounds like the lines depend on the camera.
    For example:
    New camera install (Cheap Ebay cameras) | PriusChat
    Certainly sounds like that is the case though. If true, perhaps someone will replace the stock camera with one of these some day and confirm whether that is true or not.
    52,891
    my son drove an infinity with camera's and lines all around. he said it was extremely accurate.
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If you put a screen protector on the camera with line on it, they will be out of focus and useless. You should put the lines on a screen protector on the display
    KK6PD and Les_PL like this.
  5. give dinosaurs a break
    I also have an M35X and the lines are really helpful.
  6. mrbigh
    3,686
    699
    Long Island, NY
    Is it really necessary??????????
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    What does necessity have to to with this topic?
  8. andreyco
    andreyco Member
    91
    27
    I was also disappointed to see that the back-up camera didn't have any guide lines. Drawing lines on the actual camera will most definitely do nothing (they will be out of focus).
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Exactly right. Some cameras have line generators built into them, actually all you would have to do is find a camera with lines, and if it could be mounted properly, just plug it in! I would just cut the old camera out , save the power and video cable, splice new camera into old wires.
    You now have lines!
    Tracksyde likes this.
