Campaign to repair invertor?
Discussion in 'Gen 3 Prius Main Forum' started by Steelholder, Dec 11, 2024.
  1. Steelholder
    Steelholder Junior Member
    73
    17
    Encino
    Hey all my invertor recently took a crap and is throwing code P0A94. Heard the dealer might cover the invertor if it throws this code. How likely is the dealer to dodge it?
    Car symptoms are it doesn't do over 25 or 35 mph without sounding like it's in neutral while still accumulating speed. Red triangle etc. Not throwing any other codes.
  2. Brian1954
    Brian1954 Senior Member
    2,628
    1,038
    South Central PA, USA
    Do not clear the code. Call your local dealership, make an appointment, and tell the. the code you have and that the inverter is covered by a 20-year extended warranty.
  3. Steelholder
    73
    17
    Encino
    Thanks, just got the call that they're covering it. It's the IPM
  4. Tombukt2
    Tombukt2 Senior Member
    13,778
    2,495
    Durham NC
    That's wonderful as long as you don't have to do anything to get it to the dealer and all that stuff I change the whole inverter when that happens not just the IPM there's thousands of these things out here that have already been done thousands of these cars have been taken off the road junk yards can't give away these inverters practically they just sit there with the campaign stickers on them and everything it'd be more trouble for me personally to take my car to the dealer to get that done then it will be the sling an inverter on it in about 45 minutes right out here in the parking lot I probably have three but that's good I do know that the campaign covers it for a good minute I know some people they tried to tell that that wouldn't happen but that's good for me though that takes a whole day they got to keep my car a day maybe two on and on and I can just swap it out while I'm sitting here drinking sunny d.
  5. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    @Brian1954 could you please share the TSB or Campaign PDF file?
  6. Brian1954
    2,628
    1,038
    renatomn74 and johnHRP like this.
