Camper questions
Discussion in 'Prius v Technical Discussion' started by BlueRidge20, May 29, 2020.
  1. BlueRidge20
    BlueRidge20 Junior Member
    Nashville
    when sleeping in a Prius I’d like to power a (12 volt) top loading frig and a Cpap machine.
    Would the 12v power come from the main vehicle battery, or the small auxiliary battery?
    If its the small 12v auxiliary battery will the engine cycle on and off to recharge the small battery during the night, the way it cycles on and off for heat and air conditioning?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    If you leave the car running in Ready the inverter will keep the 12v aux battery charged. Actually it won’t discharge in Ready since the inverter will supply all the 12v amps needed using the hv battery. The biggest problem is the engine will cycle more often than you might expect to keep the hv charge at a relatively low state. In other words, the engine won’t charge the hv battery to a full state. It will raise it slightly from a low state and then shutoff.
    #2 rjparker, May 29, 2020
    Tim Jones and Merkey like this.
  3. BlueRidge20
    Nashville
    Thank you for replying I appreciate the info
