Camping in Ready mode
Discussion in 'Gen 4 Prius Main Forum' started by Bill Ogden, May 29, 2026.
  1. Bill Ogden
    Bill Ogden Junior Member
    New Mexico
    I have a 2016 Prius. Looking at buying a portable car fridge. Gemini AI is telling me the following... is it true?
    1. The "Ready Mode" Trick: If you are car camping or want to keep the cooler running during a long stop, you can leave the Prius turned on in Ready Mode (parking brake engaged). The car will run cleanly off the large hybrid battery, and the gas engine will only cycle on occasionally for a few minutes to top off the battery, consuming very little fuel over a weekend.
    52,776
    yes, but more or less fuel based on draw and climate. make sure gen 4 doesn't have auto off after a certain amount of time in park.
    52,776
  4. ChapmanF
    18,957
    That's the way I do it in my gen 3.
    I remember some reports that gen 4 might automatically shut down after some period of time in READY without going anywhere, but I also think I remember there's a way to prevent that shutdown. Maybe that's in the thread bisco linked.
    You have to be aware that if you leave the car in READY when you're not there, someone can drive it away. You can lock the doors and take the key and fob with you, but someone who breaks in can still drive until they turn the car off.
    Portable car fridges come in two families, the thermoelectric kind (less money) and the refrigerant/compressor kind.
    Although more money, the latter kind can stay cool on so much less power that it can be practical to let them run for a while on the 12-volt battery while you are away and the car is off. Some of them also have a built-in low-voltage cutoff that will shut them down before they drain the battery far enough to keep you from starting the car (at the expense of your food, of course).
    With a 60-watt solar panel on the roof of my car, I can often make it through a long weekend with the fridge in the car, if I remembered to park where there's sun.
    BiomedO1 likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,519
    2,378
    Left Coast
    It's very hot in New Mexico and I wouldn't want to chance someone stealing my car - just to keep my beer cold.
    The way I do it is in a daisy chain configuration with a portable power station. lighter into power station then power station to car fridge. Power station will charge while car is running, while fridge will run while the car is off. The bonus is that you won't run out of gas in the middle of nowhere and have to walk out - because you've burned all your gas keeping your beer cold.o_O
