Camping with the hatchback open
Discussion in 'Gen 3 Prius Main Forum' started by Debbie Z, Sep 13, 2020.
  1. Debbie Z
    Debbie Z New Member
    Arizona
    I purchased one of those tents that attach to the back of the Prius that allows you to keep your hatchback open. I was super excited my first solo car camping trip. But the first night I got set up to sleep I realized the Open Door light was flashing on the dashboard. I worried about draining my battery so I ended up closing the hatch. It there are way to override this so the hatch can stay open. I did try to stick carabiner in the latch to press it down and fool the car to thinking the hatch was locked but I couldn't get it to stay in place. Do the people who created these tents not think about this issue? I was pretty far out on a dirt road camping and didn't want to get stranded out there alone. I appreciate any of your advice or feedback. Thanks.
  2. Tideland Prius
    16,621
    Are you talking about the interior lights?
    The hatch/cargo area light has an on/off switch beside the light itself. You can use that to turn off the cargo area light.
    For the interior lights (rear dome light and front map/dome lights), they're both controlled by a switch towards the front of the ceiling. Locate a switch above the shifter on the ceiling and slide it to the OFF position. This also keeps the interior lights off if you open any door.
    If you're talking about the red "door ajar" light, that should be fine (i.e. it shouldn't drain the 12V but it depends on the health of your 12V I suppose)
    Therese Rudolph and Debbie Z like this.
  3. Debbie Z
    Debbie Z New Member
    Arizona
    Thank you. I am talking about the red flashing “door ajar” light. I’ll have the 12v checked when I bring my car in for service this week.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Are you sure it was the open door light or was it the imobilizer/security light flashing. This light flashes once you shut off the vehicle.
    #4 orenji, Sep 14, 2020
  5. ChapmanF
    18,567
    I often just push that latch down with my pinky till it clicks.
    Sometimes I do it so I can lower the hatch to the bumper without having it latch. Just have to push the open button once more to spring the latch back open when I want to really close it. No need to try to get a carabiner or anything stuck in it.
    vvillovv likes this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    VERY low draw so I wouldn't worry about it. The SKS is drawing a lot more. Carry a small jump pack (you should already) for Plan B.
    Also, you can get small plastic clamps from the hardware store that could be clamped to the switch but, again, that's a very low draw if you have the dome/cargo lights set to off. Remember, many cars have a blinking "security" light on the dash anyways.
    Finally, I "camped" in my Clarity at home during a multi-day power outage and the dash lights and DRL's were unanticipated issues.
  7. Debbie Z
    Debbie Z New Member
    Arizona
    That was flashing too, but since that is standard I wasn’t worried about that.
    I tried pushing it down but it never clicked. But I’ll try that again to see if I can make that happen. Thank you.
    Thank you. What’s SKS? I did turn off my dome/cargo lights.
    #7 Debbie Z, Sep 14, 2020
  8. fotomoto
    5,639
    3,815
    So. Texas
    Smart Key System.
    Also, I would use a wooden object instead of metal to close the liftgate switch just in case it gets jammed up; especially being out in the middle of nowhere.
  9. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We have been having problems with the micro-switch in the rear hatch latch. The hatch latches fine, but the car thinks it is still open. So it refuses to un-latch, and it will run the 12v battery down over-night.
    The easy solution we have found so far, has been to slam the latch really hard.
    5 or 6 times so far, I have had to put a charger on the car to recharge the 12v battery before the car will start again.
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Pull the “dome” fuse.
  11. fotomoto
    5,639
    3,815
    So. Texas
    Yes that will solve the dash light remaining on issue but it also (obviously) keeps the dome/cargo lights from working and anything else that might be on that circuit. While laying in the back, being able to reach up/over to flick on either of those lights is very convenient.
    FWIW
  12. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Camping with no flash light on hand? :whistle:
  13. fotomoto
    5,639
    3,815
    So. Texas
    First rule of Flash lights: Never near by (or work) when you need them the most.... :ROFLMAO:
    Rodney.E, vvillovv and Debbie Z like this.
  14. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    I once left my hatch open accidentally overnight in the garage. When I saw it in the morning, I was convinced the battery would be dead since there is that rear light that turns on when the hatch is open. Turns out the Prius just shut things down on its own. I don't know how long it took for the car to auto shut-off the light, or even if the dash light was on; but I can tell you from personal experience that I left my hatch open overnight and the car started up just fine in the morning.
    Debbie Z likes this.
  15. Johnny Cakes
    Johnny Cakes Senior Member
    1,058
    786
    Virginia, USA
    Like others have said, I would not be worried about the "Open Door" light flashing on the dashboard. It is too small a drain to worry about.
    My camping is mostly stealth so I have configured the Prius not to emit a single light when I open the door. That actually involved disconnecting the door/puddle lights on the doors since they will come on when the door is open and are not switched.
    Having said that, I have had the battery drain twice when a door was left ajar. Not a single light was on, but the battery drained to the point where it would not fire up the computer to start the car. My two experiences were confirmed by Fuzzy1's vague memory (better than no confirmation at all, I guess),
    So it might be a good thing for the OP to fake the car into thinking the hatch is closed. I think I saw a thread on that awhile back.
    EDIT: Quick search and found it. Even has a video!
    Hauling lumber and driving with hatch open (annoying beeps) | PriusChat
    Ed Beaty likes this.
  16. ChapmanF
    18,567
    I ... literally ... just push the latch closed with my pinky. There is no need for any object to stay there (I would object to leaving my pinky there). It just has to be pushed to the latched position.
    Like most car door latches, it has two stages of click. To interrupt the light circuit, it has to be pushed to the second click. That takes two distinct pinky pushes: one on the lower arm of the latch to get it started, then again on the upper one as it pivoted into place by the first click.
    After the second click you can see the red door light on the dash go out. You can then use the 'lock' button to hurry the dome lights out, if you don't want to wait for their timed fade.
    For simpler tasks like keeping the hatch from latching while you have the battery disconnected, the first click is enough.
  17. Debbie Z
    Debbie Z New Member
    Arizona
    Hi! That’s my exact fear. I was able to close the hatch latch but the car thought it was still open. So I tried pushing the sensor down with my finger. The light would go off while I’m pushing it but go back on when I stopped. Did you have to recharge your battery 5 or 6 times before you discovered slamming the latch hard works or did that happen even after you slammed the latch? Thank you
  18. Debbie Z
    Debbie Z New Member
    Arizona
    Thank you! So It seems like this should trick the car to thinking the hatchback is closed and will not drain the battery. Here’s the video link if others want to view it.
    susiemw likes this.
  19. Johnny Cakes
    1,058
    786
    Virginia, USA
  20. Debbie Z
    Debbie Z New Member
    Arizona
    Thanks!!
