Camping with the hatchback open
Discussion in 'Gen 3 Prius Main Forum' started by Debbie Z, Sep 13, 2020.
  1. ChapmanF
    18,775
    That's exactly what I do, only I don't use a screwdriver, because there is (so far) always a pinky attached to my hand.
    vvillovv and fotomoto like this.
  2. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Rule # 2 have a few scattered around and the main inspector light always in one place and charged up.
    There is bound to be one around somewhere, if I could only find it .....
    fotomoto likes this.
  3. Debbie Z
    Debbie Z New Member
    Arizona
    Hi. I wanted to follow up on this conversation. I Just got back from my camping trip and the carabiner worked great in fooling the sensor that the hatchback was closed! Thank you for all of your responses.
  4. J Leonard
    J Leonard Junior Member
    Central Florida
    Didn't know there were two clicks thanks to all!
  5. Mntns and Streams
    Mntns and Streams New Member
    Kentucky
    Thanks for posting! Totally worked when I tried it.
  6. Mendel Leisk
    42,080
    I had to transport stuff sticking out the back. Tried the carabiner trick, unfortunately didn't work, had the warning beep ALL THE WAY there. Maybe wrong size? It looked close. And at least it was an effective tie-down point.
  7. ChapmanF
    18,775
    Don't forget you need the second click.
    If you need the tie-down point, that's where the carabiner comes in handy. If all you need are the clicks, a pinky works fine. You don't have to leave the pinky there after the two clicks.
