Featured Camry Hybrid LE metrics
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Sep 22, 2017.
  1. bwilson4web
    15,513
    Source: 2018 Toyota Camry Hybrid LE Matches Toyota Prius' 52 MPG Fuel Economy | Torque News
    In the case of the new 2018 Camry Hybrid, the LE uses a lithium-ion battery instead of the nickel metal hydride batteries the SE and XLE Hybrid trims use. It also has steel wheels and slightly different dimensions and a lower weight than the other two trims.
    I have long suspected steel vs alloy wheels have a measurable impact on the City driving protocol results because the polar moment of inertia effect. I would love to see the results of an alloy wheel version of the new, Camry hybrid.
    telmo744 likes this.
  2. GasperG
    GasperG Senior Member
    1,168
    598
    Slovenia
    2018 Prius
    Camry is a heavier car or is it not?
    To me the higher highway rating is more interesting, Camry has bigger frontal area, don't know about Cd but even if air resistance is the same it's still interesting, it can't be all attributed to higher 41% thermal efficiency?
    In the end I think they just understated the Prius figures a little or maybe bloated Camry numbers a little.
  3. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    Completely agree. We have already some evidence with real MPG data.
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    The Prius is better in the city and the Camry is better on the highway. I think that points to engine and possibly wheel efficiencies.
  5. bisco
    49,397
    agree with gasper. likely difficult to achieve epa in the camry, and easy to beat in the prius.
    pilotgrrl likes this.
  6. Tideland Prius
    16,128
    Look no further than Canada
    2018 Camry Hybrid MPG Table | PriusChat
    LE Hybrid w/ 17" alloys: 48/49/48
    bwilson4web likes this.
  7. bwilson4web
    15,513
    Thanks, a head scratcher other than we know larger wheels have typically under performed.
