Camry Hybrid vs Prius: Pluses and Minuses
Discussion in 'Gen 3 Prius Main Forum' started by randallintacoma, Mar 14, 2010.
  1. randallintacoma
    randallintacoma New Member
    33
    Tacoma
    I just replaced my 2009 Camry Hybrid with a 2010 Prius IV. If there are others like me out there, can you share your observations?
    I've noticed that the Camry seems to start coasting more readily and can get faster than the Prius. I routinely drive a one mile downhill grade on the way to work each morning. As the grade begins, the Camry would immediately pick up speed and I would need to use engine braking two or three times to keep the speed at the limit. The Prius doesn't pick up speed at the top of the grade as quickly and I only need to use engine braking once on the slope.
    My guess- and that is all it is- is that this difference is explained by the Camry's greater weight.
    The other major difference of course is the Prius offering 4 options for hybrid driving: normal, ECO, power and EV where the Camry offers just normal.
    One surprise: the Camry had no trouble meeting freeway speeds on entering. I don't know what the 0-60 time is, but the Camry never felt slow on freeway entrances. The Prius does feel slow in normal and very slow in ECO. Power mode on the Prius however was a pleasant surprise. In that mode, the Prius matches the Camry in freeway merging.
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    What are the specs of the engine of the Camry compared to the Prius? What is the weight delta between the 2 models?
    Plus, you have a break-in period of about 5000 km - my personal feeling, but not substantiated by any fact whatsoever, only my impression, the ECU is managing the Prius a bit differently in these first km.
    I have absolutely no problem to merge in the Autobahn (where the average speed is, even in the right lane, often 130km/h....) and never really felt the lack of acceleration.
    It also depends, as you say, on what was the performance of the Camry to which you were used to. You might have to push the Prius a bit more than the Camry, therefore I asked you at the beginning the specs of the Camry - Camry Hybrid is not sold in Europe.
    The Prius does 0-100km/h/62mph in 10.4 secs. I don't know if this acceleration is dependent on the mode you select - I cannot test it. Most would say it is not the case, though my experience and gut feeling tells me that the modes affect way more than just the response to the accelerator. I think it changes completely the way the HSD is managed. E.g. I cannot get at all the same performance in ECO as in Normal or as in PWR - it's like driving 3 different cars (even when the HSI bar is completely in the red zone - I have to test the same effect when I floor the accelerator - but I need a free stretch of road and in Europe it is not easy to find one, especially a straight one... ;) ).
  3. patsparks
    10,664
    567
    Adelaide South Australia
    If you actually push the accelerator to the floor the acceleration in eco and power mode is exactly the same.
    I can't imagine this is answering your question but don't use B mode unless the battery will be full by the bottom of the hill, light foot braking will add charge to the battery, it won't use friction brakes.
  4. Tideland Prius
    16,443
    Camry Hybrid:
    Engine: 2.4 litre VVT-i I-4
    Hp: 138hp
    Net Hybrid hp: 187hp
    Weight: 1,650kg (Prius = 1,360kg)
    0-60: ~8.7 sec
    FE: 5.7/5.7 L/100km (city/hwy)
  5. pakitt
    2,173
    1,313
    Colorado
    Well, then obviously the Prius is not going to feel as snappy as the Camry Hybrid!
    The Camry is 21% heavier, sure, but 37% more powerful and reaches 60mph/100km/h in about 20% less time. No wonder... :)
    Thanks Tideland for the data.
  6. pakitt
    2,173
    1,313
    Colorado
    Are you sure? did you try this on a Gen 3? (asking because I see you have a Gen2 Prius)
    My feeling is different. BTY the modes affect also EV mode. If you have PWR Mode on, for the same length of the HSI bar the car accelerates more. So the mapping of the accelerator sure works on EV mode as well.
  7. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Yes it would be a huge danger aka lawsuit if the car was truly slower in one mode compared to another. If you floor it it will be no faster in power than it will be in eco mode.
  8. pakitt
    2,173
    1,313
    Colorado
    Adamace1, sorry I don't understand what you say. In which way a car with slower reaction times in one mode instead of another would result in a lawsuit or being a "huge danger"? Please explain.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes, we are sure. It has been tested by many on PC and was also explained to us by the Prius chief engineer when talked to him in Detroit. Full power is available in all modes.
    Tom
  10. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    The huge plus of the Camry for many folks who take big road trips, esp. with family is the real, good size trunk.
    I would rather have a real trunk, but you probably notice it didn't convince me to go Camry rather than Prius.
  11. toyolover
    toyolover Member
    441
    67
    toronto, canada
    You can't really draw a comparison btw the two as they are designed with different objectives. The Camry Hybrid is to reduce the fuel consumption than its gasoline cousin while the Prius is to maximize fuel economy to its last drop. I believe people buying Camry Hybrid and Prius are for totally different reasons. For me, I bought the Prius for its thrifty in fuel, its style, its friendlyness to the environment and the image it projects on me. If you don't compare an apple to an orange, why compare the Camry to Prius?
  12. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Apple: fruit that grows on trees, has a skin and pulp, a color in the red end of the spectrum, and you make juice out of it.
    Orange: fruit that grows on trees, has a skin and pulp, a color in the red end of the spectrum, and you make juice out of it.
    Anyway, I had a 2004 Camry Hybrid, J-code. The mileage was in the 38 mpg range. The pick up was good, but it "motorboats" very readily. The ride was more plush, and the interior was quieter. The trunk is VERY small in the Camry Hybrid, however.
    I got a 2010 Prius IV for the mileage since I have an 80 mile per day commute in and out of Washington, D.C. The ride in the Prius is louder, more starter car quality. It reminds me a lot of my 1984 Ford Escort. The steering is much faster in the Prius, and the Prius in Power mode is MUCH faster than the Camry getting on to 95.
    I do miss the quiet ride of the Camry. It did coast a lot more readily than does the Prius, but with 56 mpg on a weekly basis, I'll take the Prius.
  13. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Just as you can't draw a comparison between the Camry Hybrid and the Prius you can't assume someone else's reason for buying a particular car. For instance two of the three reasons you listed to show why you chose a Prius are different than mine. Thrifty fuel - match. Friendly to environment - not a factor in my decision. As for the your liking the image it projects, I bought the Prius despite the image it projects. :)
  14. pakitt
    2,173
    1,313
    Colorado
    :D
  15. randallintacoma
    33
    Tacoma
    To mmcdonal: Thanks, your observations are identical to my comparison between the two cars. I didn't mention in my original post that the Camry is quieter than the Prius, but I agree with that observation. It just seems that I rarely notice this because the Prius offers me even more options to play music than the Camry did (Bluetooth and USB), so I doubt I will ever hear the road sounds.
    To toyolover: I appreciate your comments, but I think I did purchase the Camry and the Prius for the same reasons: the hybrid technology and better MPG than I was getting in the Camry SE V6 I had. When I bought the 09 Camry hybrid, the issue was I felt the overall comparison between it and the Gen II Prius wasn't enough to get me into a Prius. The Gen III corrected most of that and the current Toyota financial incentives took me the rest of the way.
  16. bisco
    51,113
    we have an 08 hycam and prius. pri gets 55 avg, cam gets 40 avg., we love the pri but boston to florida is a luxurious ride in the ca. quiet, smooth, powerful, i drive the pri, bride drives the hycam. two different cars but the neat thing with the hycam is coming out of a camry you see the difference where the pri stands alone and nothing to compare it to.
  17. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I didn't mean to offend anyone who wish to compare the Camry Hybrid to the Prius. All I was trying to say is Camry Hybrid and the Prius are two very different cars even thought they both have the HSD. Their design objectives are different. Their target customers are also different. It would be fair to compare Camry to Accord or to Altima; or Camry Hybrid to Nissan Altima Hybrid or Fusion Hybrid. I feel that the only appropriate comparision to Prius is the Honda Insight. (Don't hang me for saying that. :mod:)
  18. GadgetCar
    GadgetCar Junior Member
    San Antonio, TX
    I have a 2008 Prius and was looking at a Gen III. I decided to by a Camry Hybrid instead. The Camry is very quiet and accelerates a lot better. The car is significantly more comfortable for long trips. In the first 2,000 miles I'm getting about 37mpg. In 30,000 of driving the Prius I averaged about 44mpg. The well equipped Camry was also less expensive than a fully equipped Prius.
  19. prius4driver
    prius4driver Junior Member
    74
    Sublimity, Oregon
    2018 Prius
    We didn't want a sedan, so that let out Camry and Ford. I use ECO most of the time but found that Power gives a tremendous kick of acceleration. I use a tight 360 degree ramp onto a 55 mph divided highway with a pretty good hill at times. In ECO I'm only getting about 35 mph with pretty heavy pressure on the accelerator. Hit ECO, and with the same pressure shot to 60 very quickly. This car isn't sluggish if driven correctly!
  20. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Sounds good. From the Pluses and Minuses it doesn't seem that much. If the Camrys are better made I probably go with a Camery. 50+ mpg compared to 40 mpg I dont think it wiill bother me much especially I used to do less than 10 mpg with the Acura RL.
