Camry hybrid?
Discussion in 'Toyota Hybrids and EVs' started by OmaramO, Jun 15, 2015.
  1. OmaramO
    OmaramO Junior Member
    36
    Fremont CA
    Hey guys I've been working on 2nd gen Prius hybrid batteries for a while now. Recently I have been getting a lot of calls for working on Camry batteries. I usually turn them away but decided to take one on. Has anyone on here worked on one? Are the cells the same? Is it also 28 cells? Any other tips tricks or anything I should known about while working on the Camry vs the Prius?
    Thanks in advance !
  2. JC91006
    16,482
    8,400
    What? You are going off the advice on forums to use on your customers?
    49,500
    just hycam customers.;)
  4. OmaramO
    36
    Fremont CA
    I was just asking if there was any differences I should know about. I appreciate the response. I'm not sure if it's taboo to ask for advice with customers. If it changes anything it is actually for a relative that I'm not charging to do the work that's the only reason I agreed to do a Camry since I never have before. I go on these forums religiously for advice and if anyone has any for me it would be more then appreciated.
  5. Binterest
    Binterest New Member
    Riccarton
    Hi , I've a 2009 Camry Hybrid and what engine diagnosis should I use?
    Because I'm seeing possible future sighs of problems
    Thanks much
    Bblog
  6. bisco
    49,500
    use tech stream, that's toyota's official software. you'll need an old windows laptop.
  7. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    The modules in the camry are exactly the same size as the prius, what i don't know is if their internal resistance are exactly the same. The camry has 34 modules unlike the 28 in the Prius. I have worked on two camry batteries and used the same principle learnt here.
  8. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    The 34 Camry modules are usually the B2 modules which may have a different series resistance. Make sure you match up the modules correctly. Taking apart a Camry battery is a nightmare the first couple times. Take lots of pictures for future reference and to get it back together properly.
    Jess Norris likes this.
  9. Dave G
    Dave G Junior Member
    Mesa
    I have been asked to work on the camry hybrid packs as well. I have opened one but need to know how the banks are numbered so I can match the battery bank to the DTC. Any help is appreciated.
  10. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    you would think, Toyota is like the gm of japan that they use a lot of the same parts that are used in other toyota hybird cars I would think the same for the ( Panasonic made battery's for Toyota) that they would be the same, just my 2 cents I thought I throw in.
  11. Tideland Prius
    16,155
    You would rather he work on it without? It's a forum. It's a place to ask questions.
    Raytheeagle likes this.
  12. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...cut 'im a break, statute of limitations is past 2 yr old post;)
    Raytheeagle and Tideland Prius like this.
