Cams slipped need help setting it right
Discussion in 'Gen 3 Prius Main Forum' started by johnnychimpo, Jan 16, 2021.
  1. Mendel Leisk
    42,341
    I’ve got a vague recollection from one of the two “good” Gasket Masters DIY videos (now taken down), they say the intake cam mark should be roughly around 2 o’clock, and as long as the chain, cam and crankshaft marks all match, you’re good.
    Per @The Critic too, regarding chain slack all on tensioner side?
  2. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    I don't want to take this cover off but I'm going to I think my cam marks are good. Can someone please confirm me 16109022899234839449217616217829.jpg 16109023105074504895752733821334.jpg 16109023303276022788205061907752.jpg 16109023478365472933124146047817.jpg 16109022899234839449217616217829.jpg 16109023105074504895752733821334.jpg 16109023303276022788205061907752.jpg 16109023478365472933124146047817.jpg
  3. Mendel Leisk
    42,341
    I’ll defer to the pros, nice pics though.
    One thing, looks like there’s a gap or two in the form-in-place gasket application, in that last pic? One thing I like about gasket masters: they put regular, close-spaced dabs all around the perimeter, then spread it out uniformly with a finger. It’s not exactly how Toyota describes, but seems very bulletproof.
    To be fair: maybe some clung to the cover when you pulled it off.
  4. johnnychimpo
    522
    112
    Monterey
    Okay put it back together start it up ran just fine then started to knock I'm out of ideas could you need gr any suggestions just clean the EGR prior to all this mess by the way
  5. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    The knocking could be from any left over oil, or eccesive fuel from cleaning.
    It should clear up fairly quickly. How long did you let it run?
  6. johnnychimpo
    522
    112
    Monterey
    Car still knocking it looks like spark is leaking from one of the coils and I hear a winding noise coming from the fuel rail I'm thinking bad coils and bad fuel injectors any thoughts still knocking though and like I said when it starts it runs fine for about two minutes and then it starts to knock so I don't think timing or head gasket is an issue
  7. johnnychimpo
    522
    112
    Monterey
    Till it died
  8. ASRDogman
    8,063
    4,086
    If you hear a whining/hiss, maybe a fuel leak? Are you sure everything is tighten for fuel related parts?
    Spark is leaking???? Did you clean the injectors while they were out?
    If you me arching, that's not good, if there is a fuel leak. Are the spark plugs tight?
    Maybe a cracked coil?
  9. johnnychimpo
    522
    112
    Monterey
    It's more of a winding sound like a bad bearing but it's only in the fuel rail which is odd there is no odor of fuel and yes the coil is arcing I've ordered some new coils should be here by Tuesday I suspect the knocking is the anti-knock sensor as I understand it from the electric motor can somebody confirm that for me thanks for all your help guys
