Can a 1.5 prius C engine be installed into a 2006 prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Grahams2, May 5, 2017.
  1. Grahams2
    Grahams2 Junior Member
    Crystal beach, Ontario Canada
    My 2006 prius engine has died and I have an option to buy a prius C engine at a great price..
    Can a 1.5 prius C engine be installed into a 2006 prius?
    NortTexSalv04Prius likes this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    You would need to compare them to know for sure.
    Wild swag is that harness exhaust and other crapola would be different and require more effort than a proper gen ii
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    It could be done; but I suspect the cost would be prohibitive.
  4. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Certainly not a drop in fit. Might need to change the engine control ECU. C has an electric water pump. Better, but you'll have to find some power for it. Probably want to retrofit the belt drive water pump onto the C engine.
    PriusMechanic likes this.
  5. PriusMechanic
    PriusMechanic Junior Member
    CA
    I am interested to know as well. And why is everyone replying "no it can't be done" without any explanation. They are both 1NZ-FXE engine.
  6. PriusMechanic
    CA
    Do you think the timing might be different for the 2 engines? Do you think I can just change all the sensors from the old engine to the Prius C engine and make it work?
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    The more I think about this the more I like the idea. There just aren't many low mileage Gen2s out there any more. You could probably find a very low mileage Prius C engine.
    The main problem I'm aware of is the water pump. It might be a trivial transfer of the old parts to the new. Or it could be a real bummer if you need a new crankshaft. You really need to check this aspect out carefully. Other than the water pump, my guess is that putting all the old electronics on the new C engine would work.
    Back in the stone ages I helped a friend put a 1956 engine into a 1951 Chevrolet. It was a perfect fit - the motor mounts were all the same, the clutch/transmission mated up perfectly. The latest new technology in the 1956 engine compared to the 1951 was pressure lubrication :eek: . The 1951 used splash lubrication - no oil pump, no oil filter. Technology marches on...
    Raytheeagle and Kevin_Denver like this.
  8. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    A major challenge could be the electronics. Will a gen 2 engine ECU work correctly with a Prius C engine installed on a 2nd gen transaxel? I don't know. I would compare differences between the C and 2nd gen engine, sensors, and wiring. It may be needed to pull some of the sensors off of a 2nd gen engine and mount them on the C engine, and possibly fake some sensors (water pump) with a resistor, etc. I would look at wiring diagrams for 2nd gen and C and see what differences exist both for wiring and sensors before getting into the middle of the project. My guess is there are some changes to the C's design.
    Super cool project if you do decide to do it. Post plenty of pictures and what gotchas you run into for those in the future that decide to do this.
    NortTexSalv04Prius and RobH like this.
  9. Grahams2
    I ended up putting a Yaris engine in my 2006 prius physically its identical, I used the existing clutch & gearbox from the prius, all the sensors wkd fine & I have just done 8,000 miles with no issues
    James Analytic, 2Fats, SFO and 2 others like this.
  10. bisco
    52,886
    congrats and well done!(y)
  11. RobH
    RobH Senior Member
    2,385
    991
    70
    Wow! Did you change the engine ECU to match the Yaris? How is the power & mileage?
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Unless you somehow got a hybrid version from Europe, the N.A. Yaris (1NZ-FE) is a conventional otto cycle engine and the prius doesn't have a clutch nor a "gear" box.
    Kevin_Denver and Prodigyplace like this.
  13. PriusMechanic
    CA
    I would like to know more detail about it too. Did you notice more power and lower MPG? I know they are physically identical, but like fotmoto said the Yaris is a otto cycle engine. I am really surprise you can just interchange the two! Nice work BTW!
  14. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    The Prius' engine is mechanically an Otto cycle too, it is modified in operation to an Atkinson cycle by computer control of the variable valve timing (VVT). Therefore the Yaris engine should function the same using Prius computer control modules.
    PriusMechanic and fotomoto like this.
  15. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The intake manifold of the Yaris engine probably is different so the Prius intake manifold would be needed to make it work.
  16. audiodave
    audiodave Active Member
    800
    272
    US
    Be curious to know if any power difference too. Yaris engine definitely has more power.
  17. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    cam timing is different; compression ratio is lower on the yaris too. if the c has a truly identical block, then the water pump isn't an issue. seems to me the crank might have a belt groove in the balancer even though it isn't used.
  18. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You're very correct. People should provide alternative solutions. For me, the op should compare the transmissions, and or go through alldata for the schematics of wiring diagrams, and layout.
  19. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    ...i
    I also did transfer sets of pistons from a Yaris engine, to a 2006 Prius I recently overhauled. They basically had the same diameters.
  20. 69shovlhed
    2,170
    752
    Delaware
    did the yaris pistons have the same top? prius is rated at like 13-1 compression. I would expect the piston crown to be very different, unless the cylinder heads are different.
